Question about HP LaserJet P2015dn Printer
Hp laserjet p2015dn prints one page and then goes offline. i delete the job, then turn printer off. Sometimes, it will show online and sometimes offline. Also, when I shut printer off the light may stop at one of the other positions in stead of the ready light. If I shut the printer off, the lights may set at ready or may not. I have tried changing the usb cable and downloading the latest software. But nothing seems to work.
  • HP Master
  • 1,915 Answers
Known issue with these printers. The formatters fail at an alarming rate. At one point HP was replacing them under an Extended Service Advisory, but they have discontinued that program. You could try calling and raising a stink and they might do something for you. Otherwise, check on Ebay, likely someone is selling used formatters.
Posted on Mar 16, 2011
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    My Hp laserjet p3005 drops offline and cant print, any help
    Go to system settings and select the 'Printer' option.
    Right-click on the printer and enable the 'Use Printer Online' function.
    Cancel all the printing jobs till that moment and redo the process.
    Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
    Check all network connections and functions.
    Be sure the network interfaces work properly.
    Turn the printer off and on to see whether the device is working properly.
    Sep 06, 2011 | HP LaserJet P3005 Printer
    When i print from hp deskjet D1560 it dose not print. It automatically shows offline when i print even though it is not offline. And it dose not print self test page also. pls give an instant...
    Aug 19, 2011 | Office Equipment & Supplies
    Cannot change the offline status of my HP printer. It will print a diagnostic page. Also a job is stuck mid-deletion and will not go away.
    May 25, 2011 | Office Equipment & Supplies
    My HP laser jet P2015dn stopped printing in the middle of a 137 pp Tjob. Press the reset button. Now the printer says it has "Insufficient Memory". There are no other jobs in the...
    -Open printer icon in your computer and delete all the job printing
    there. And press cancel bottom on the printer many times as well.
    -If there are so many page, the printer can't handle, you need to print 10 pages per time only.
    Good luck
    Mai
    Jan 16, 2018 | HP LaserJet P2015dn Printer
    Need to increase memory for HP LaserJet P2015dn
    hold down go button until light blinks & if the memory amount is below 128 you can add a stick in the side slot.
    Jan 16, 2009 | HP LaserJet P2015dn Printer
    HP LaserJet P2015dn Printer Logo
    417 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
