Question about Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint aquarius washing machine is 8 years old (wmm39) . Does it have a filter and if so where is it located
    Brigadier General:
  • 6,277 Answers
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 15, 2011
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Where is the filter located on a Hotpoint Aquarius WM63 washing machine?
Remove lower rear panel of washer.
Locate and remove the large black hose from bottom of drum, remove and clean the filter inside the hose.
Oct 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Drum has stopped moving
Hello, these is usually the drive belt,the drive belt is the easiest parts to replace.
Thanks
Jun 10, 2010 | Hotpoint WMM39 Front Load Washer
Washing machine doesnt empty or final spin
You need to check the filter.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Mar 12, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint wmm39 aquarius extra washes but does not spin
you are in an unfortunate delemer. It is either your spin winding thats gone or the control board or timer thats faulty. Normally a technician has spares to test against to prove by process of elimination.Aquick test, pull the pressure switch pipe off the drum assy. and retry spin cycle. Alao take note if all water is drained out of the tub. Let me know
Sep 25, 2009 | Hotpoint WMM39 Front Load Washer
Hotpoint wmm39 contol panel
The instruction book below has a picture of the control panel on page 17,from the off position turning clockwise the control dial is lettered position 1 = A, 2 = B etc http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HBWMA48.pdf
Jun 11, 2009 | Hotpoint WMM39 Front Load Washer
Can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Feb 19, 2009 | Washing Machines
The 2 wires on the pump of a hotpoint aquarius have come off
Does not matter which wire you put on terminals as they are both common, it will work regardless of which wire you put on.the terminals.
Trust me on this
plz leave feedback for this solution
Dec 12, 2008 | Hotpoint WMM39 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
37 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
