Question about Dell Inspiron E1505 Notebook
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell is sending me the new Windows XP operating system discs as they did not come with the PC when purchased new. Want to know if I load Windows XP, then format HD, or vice versa, etc... Thanks in advance for any help.
  • 3 Answers
You need a windows xp installation disc, if you have this installation disc, then you can go on and format your laptop using the installation disc. if this is your first time to do a "fresh install", this link will give you a step by step guide on how to do it. How To Install Windows XP
Posted on May 30, 2014
    Guru:
  • 767 Answers
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Posted on Mar 15, 2011
Strange faint gray/blue screen
It sounds like there is a critical error in loading the operating system, most likely caused by a corrupted file or key in the registry. Your options are: A) Spend countless hours[days] troubleshooting and experimenting trying to repair, or B) back up your drive, wipe, and re-install. I would obviously go with option B, as it will save hours, if not days of your life. Here is the easiest route to solve. (Note: you sound like you know your way around computers, so I am assuming you've already tried booting into safe mode.)
Here are the steps to getting your files off and re-installing a fresh version of Windows 7 RC (it's free to test, remarkably stable, and will continue to work until June 2010)
1. Power off computer, unplug, remove battery. 2. Remove hard drive (here is a how-to: http://support.dell.com/support/edocs/systems/ins6400/en/sm/hddrive.htm#wp1128924) 3. On a separate computer (obviously) download and burn Windows 7 to a DVD (get it here: http://www.microsoft.com/windows/windows-7/download.aspx ) 4. Hook the hard drive you took from the e1505 to your secondary computer. It should be a SATA connection, which most newer computers i've seen contain those connections. So you should be able to plug it directly into a desktop PC. If not, dig out an external hard drive, pop out the screws, and hook up your SATA e1505 hard drive to the SATA connection in the ext hard drive, power the ext hard drive and plug the USB into your secondary computer. Either way you connect it, the computer will recognize it as a storage drive and you can simply copy the whole thing to your computer for sorting out later. 4. Once backed up, and your Win7 DVD is burned, pop that harddrive back into your e1505. 5. Turn on the laptop and put in the Win7 disk and start the install process. 6. Enjoy your fresh OS (and yes, it is compatible with windows xp programs -- just check the box for Compatibility under the right click-->properties) 7. transfer your back-up files to your e1505 8. crack open a beer and laugh at the hypothetical you that would still be beating his head in trying to figure out wtf file is missplaced or corrupted.
cheers!
Jul 14, 2009 | Dell Inspiron E1505 Notebook
Won't load windows
Try pressing F8 on startup to start the computer in safe mode.
If it does not restart in safe mode, then you need to reinstall Windows using the recovery CD or a Windows setup disk.
If you do not format the hard drive , and do a windows upgrade setup on top of same system folder, you will preserve your data.
Apr 28, 2009 | Dell Inspiron E1505 Notebook
CD/DVD drive not recognized by system and not working at all!
in windows xp: go to start then control panel then system then hardware then device manager then remove anythig that even remotely looks lika a DVD drive then: shut down you computer when it restarts xp will look for and, install anything hooked up to it automaticly
Dell inspiron 8100 notebook
You may need to try installing windows xp. I had a gateway that had a brand new hard drive and wouldn't take 98, but installed xp flawlessly. Look at the computer and see if it says designed for Windows XP
Jan 20, 2009 | Dell (0K724) for Inspiron 8100 40 GB Hard...
Laptop freeze's
are you sure it freezes or Its just taking a long time to load ...after instalation of new sp system has to reconfigure.also have you installed correct sp2 version.If youve installed wrong version possily it has crashed and youll have to reinstall os and then install sp.I use xp sp3
Jan 06, 2009 | Dell Inspiron E1505 Notebook
Having problems upgrading my laptop hard drive !!!
From what I gather basically you want to copy everything off of your 40GB and put it on the new 320GB and the install correct? Why don't you do a backup (Start>All programs>System Tools>Backup to the external 500GB drive. Install the new 320GB drive and then load the operating system from your operating system disc, then restore the data from the 500GB you backed up, or am I missing something.I know it is not as convenient as cloning but sounds like you may need to do it the old fashion way..there is no good reason that the cloning software would quit reading your disc unless it's some kind of "only get one chance and throw away software".
Dec 27, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 won't boot
Try this site to look for hard drives. Not just any drive will work, so make sure you confirm with the company's sales or tech support to make sure it'll work.
LINK
Dec 11, 2008 | Hitachi Travelstar 5K100 HTS541060G9SA00...
Dell Inspiron E1505 Notebook Logo
191 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
