Question about KVH Azimuth 1000 Compass
Where to hook up compass hot wire I am not hookig up my gps to it
Compass reading on GPS 60cSx about 30 degrees too high
Calibrate the compass (Main menu --> Setup --> Calibration --> Compass), follow the instructions on the screen.
Also, see page 50 of the manual.
Calibration must be done outside - stay clear of any large metallic object (e.g. car).
Mar 11, 2010 | Garmin GPSMAP 60CSx GPS Receiver
Compass 'pops up' in middle of a training run - want to stop this
You are in the mode that is used to navigate to a location. When the compass is up, hit the "quit" button, then select "stop go to" and it should stop.
Jan 25, 2010 | Garmin Forerunner 405 Handheld GPS...
Furuno Navnet 2. Course up incorrect
you simply need an electronic compass hooked to it. without motion, the GPS does not know which way is up
Dec 19, 2008 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Tomtom 720
New version of software (8.010) takes the compass preferences away. Compass always pointing north is available through the status bar settings. Found this on tomtom support under question, "How do compass settings work?" It has both new and old versions of how to access the compass.
Nov 09, 2008 | Tomtom ONE GPS Receiver
Etrex vista cx
Hi, the DOT (Direction Of Travel) arrow will only appear on the Compass page when you are navigating.
  1. Go to the 'Main Menu'
  2. Select 'Find'
  3. Select 'Waypoints'
  4. Select a waypoint
  5. Select the 'Go TO' button
Once you are on the Compass page you should have the DOT arrow as long as you have a sat lock.
Jun 22, 2008 | Garmin eTrex GPS Receiver
60CS
Your electronic compass is probably turned on, and if so, either it is not calibrated or you are not holding the GPS unit level.
Try turning off the electronic compass by holding the PAGE button in for a couple seconds. With the electronic compass turned off, the GPS will instead show direction of travel using the current track, which is probably what you are expecting.
Cheers!
May 30, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin HCx GPS unit
The Vista HCx has an electronic compass. You don't need to be moving for it to work, but you do need to calibrate it. To calibrate the compass:
  1. Go to the Main Menu
  2. Select Setup
  3. Select Calibration
  4. You will be asked "Which Sensor Would You Like To Calibrate", select Compass
  5. You will see a page that says "To Calibrate Compass: Slowly Turn Two Full Circles In The Same Direction While Holding The Unit Level", select Enter and do this.
You need to hold the unit level for the Magnetic Compass to work correctly. The specs for a properly calibrated compass are +/- 5°
May 15, 2008 | Garmin eTrex Vista HCx Handheld GPS...
Compass
I have read the 400 has no compass. Only 600 and higher...
May 03, 2008 | Magellan eXplorist 400 GPS Receiver
KVH Azimuth 1000 Compass Logo
18 people viewed this question
Top KVH Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a KVH Boating Expert? Answer questions, earn points and help others
