Question about Invacare P9000 Xdt Motorized Wheelchair
Where can I find the pin out diagrams for a P9000 XDT motor so that I can ohm it out?
  • 31 Answers
Chairs with motors that have a rectangular connector are what I am going to describe.
There are two round pins in the center of the motor plug. These two are for the brake coil. Ohm readings should be between 40 and 80 ohms. The motor reading is takin from the contacts on each side of the brake pins. Should ohm between 0.5 and 5 ohms.
Posted on Apr 07, 2011
I have an Invacare P9000 XDT wheelchair. I keep getting flashing lights 8 times, indicating controller fault E08. I have extra parts I got from a junk yard but still get the same fault everytime. I've...
Hi DREADFULPCBU
There isn't much to the P9000 joystick and controller. First and formost have your batteries load tested to ensure you have 24 volts dc. That in itself may solve the problem. I would then check each and every wire connection to make sure there is good continuity on all metal connectors. Check the voltage to ensure ther is only 24-27 volts dc. You could also have an over voltage possibly caused by a short somewhere. Has your chair ever gotton wet? If so one of the motors could be shorted out. Test this by taking out the motor brushes (one at a time) .See if it has water or oil on it. If so you may need to replace that motor. If all that is ok then here is where you can send your joystick and controller for repairs. ( I'm not confident that the ones you got from the junk yard are good.
PG Drives Technology Inc 2532 East Cerritos Avenue
Anaheim,
California 92806-5627
USA
Tel: +1 714 712 7911
Fax: +1 714 978 9512
www.pgdt.com
Good Luck
mimobility
Apr 30, 2011 | Invacare P9000 Xdt Motorized Wheelchair
WHY IS MY CONTOLLER FLASHING ? My power chair
Here is a link with descriptions of the flashing controller lights for most power wheel chair controllers. This will allow you a fast diagnosis to save time and money on your repair; it may be as simple as a brake reset instead of a costly motor replacement! The first page you will see is especially for Hoverounds, but you might be able to find other brands if you know the manufacturer of the controller.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Dec 22, 2010 | Invacare P9000 Xdt Motorized Wheelchair
Just recovered my stolen chair and batteries are gone what will it cost me for batteries
It depends on the type of battery, but MOST LIKELY you need type U1, 24v 33 amp (check your owner's manual). Your insurance may still cover the replacement if you can wait for the process to go through, otherwise you can purchase them at Batteries Plus or Interstate Batteries.
Dec 18, 2010 | Invacare P9000 Xdt Motorized Wheelchair
What does f25 eror mean
F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel– remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch.
The f25 error code is a motor tachometer error. To determine the problem you will have to remove the top cover and the front access panel. On some models, the rear panel will have to be taken off for easier access to the motor control. Now with the washer-unplugged remove the each plug one at a time and make sure the pins in the connector are not bent then reseat them on the board. Now retest the washer. If the washer still fails, you will need a meter to ohm the motor.
With the washer unplugged, locate the motor harness. Now unplug the motor connector to ohm the motor. Follow the list below to check the motor.
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
* Pin 4 to5 115 ohms
If the readings are close to what is listed above the motor is fine.
Live voltage checks are dangerous, and possibly deadly. Exercise caution at all times. If you are not comfortable working with live electricity I suggest you call an experienced service technician. I have provided you with a wire diagram with what the voltages should be. If the voltages are correct I would then recommend that you replace the motor control.
http://media.fotki.com/1_p,ssqftgqdqbftqgbxgtqsskgwtqkq,vi/sbbsgkqrgxstbrqrgwf/1/1303472/5961857/image5533851340308453439img-or.jpg
http://media.fotki.com/1_p,ssqftgqgtstgdfrxgtqsskgwtqkq,vi/wwkfkbqwwxkftrskdkw/1/1303472/5961857/image1769329000959650960img-or.jpg
http://media.fotki.com/1_p,ssqftgqbrdddksdxgtqsskgwtqkq,vi/stbrqrgwfxsbdkgqfbr/1/1303472/5961857/image5269611314094350944img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet ht does not finish the cycle and it gives an error code f25
F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel- remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch.
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
Mar 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore he2 plus front loader washer machine has a code F25 what do I do?
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
Feb 15, 2010 | Kenmore HE2 Plus Front Load Washer
Code f25 error kenmore elite he5
Nov 09, 2009 | Kenmore Washing Machines
How to fix a code f25 for kenmore elite he5
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
Nov 09, 2009 | Kenmore Elite HE5t Washer
Whirlpool washer wfw8400tw codef25
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Keep getting F than 7
The central control unit has detected a short in the motor contol unit. If a failure occurs during the high speed spin the door will be locked after 3 minutes.
Potential causes
1.Check the wire harness connections between the drive motor and the motor control unit and between the motor control unit and the central control unit.
2.Check the MCU... The mcu motor connector has 5 pins. pin 1 is at the top then 2345 going down
Pin 1 to 2 = 6 ohms
pin 1 to 3 = 6 ohms
pin 2 to 3 = 6 ohms
3.Check the Drive Motor
pin 1 to 2 = 6 ohms
pin 2 to 3 = 6 ohms
pin 1 to 3 = 6 ohms
4.Check the wire Harness
Nov 21, 2008 | Kenmore Elite 45986 Front Load Washer
Invacare P9000 Xdt Motorized Wheelchair Logo
129 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
