Question about Health & Beauty
The bucklle on the bag that closes the flap over the front of the bag is missing I lost it and would appreciate if you could replace it for me . THANK YOU GLORIA ABRAMOWITZ
3 Suggested Answers
mastersaintx
  • 928 Answers
SOURCE: flap that closes memory card broken
To be sure that you get the right parts you can go to the link below then go to the Store. This is the official parts store of Olympus
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Posted on Oct 26, 2008
  • 109 Answers
SOURCE: its missing plastic flap in front of machine
You can order one from Ron at a1sewingmachine.com. Look in your manual to give him the correct terminology.
Posted on Aug 23, 2010
The seal or flap between the french doors doesn't retract
check it closely something has broke an the flap is not closing as u close the door
Jun 28, 2014 | Samsung RS2556 Side by Side Refrigerator
Need to replace flap on cmm1200
1. Push the mower down to its lowest mowing position.
2. Turn it up on its right side, so the left side is in the air.
3. The existing flap is held in place with a glob of glue at the left (now top) end. Remove the glue by whatever means you like. I "chiseled" at it with taps from a flap-blade screwdriver and hammer.
4. Now you can slide the remnants of the old flap out and slide the new one in. You'll have to bend it slightly even with the mower in its lowest position to get it past the wheel, but it shouldn't be close to breaking.
5. Replace the glob of glue with whatever you have handy that plays well with plastic and rubber. By coincidence I already had DAP Alex Ultra 230 Black loaded in my caulk gun - worked fine.
Apr 07, 2013 | Black & Decker 19" Electric Lawnhog...
Its missing plastic flap in front of machine
Dec 16, 2009 | Brother SE-270D Computerized Sewing...
Isolated hard starting
It sounds like your carburetor is flooding, check to see if the choke is set too tight.
to do this, when the engine is cold, remove the air cleaner assembly, push the gas pedal one time to the floor. in the carburetor throat is a flap, this flap closes as engine cools so the engine receives more fuel for cold weather starts, the flap is at the top of the carb. this flap should have about a 1/8" gap between the throat wall and the flap when it is fully closed, if if is completly closed it will give the engine to much fuel and cause it to flood. if you need to adjust just follow the linkage that the flap is attached to, and it will lead you to the choke housing, this is where you can adjust it.
once this is done start the engine and let it warm up, as it warms up this choke flap should open completly up in a vertical position.
if it doesnt, then you probably have lost power to the choke housing or your heat tube that comes from the exhaust manifold to the choke housing is bent, off or missing. most likely yours will be electric.
i hope this helps, good luck
May 20, 2009 | 1999 Chevrolet Malibu
Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Apr 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kohler Rialto flap valve leak
if so cut 1/4 inch off the bottom of round part of flat valve
Feb 23, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Sebo felix upright
Hey Debs
Ive got a Sebo Felix. Unfold the bag (if its folded) and drop it into the top of the bin. Once you've aligned the plastic parts the two nibs which are pointing outwards towards the handle, make sure the plastic collar is sitting on the rest of the surround.
Now the most important aspect is the plastic flap - not the dust cap - but if standing behind the Felix, there is a green flap on the left hand side of the bag which must be pushed down over the spring (looks like a large staple). Once that is folded over and locked in, the lid should close. If the lid still doesn't close check that the top hose fitting has been securely locked and is dust free. Dont forget to rate, ty.
Jul 25, 2008 | Sebo Vacuums
Dyson DC07
Hi.
If you look at the front left side of machine there is a removeable inspection port it will have 2 coloured buttons you press these in & pull it up to remove.
Now pull handle back as if vacuuming the floor.
Now where the inspection port was you will see that there is a square hole pull forward on the flap in front of square hole it pivots just behind the round rubber seal.
Slowly lift handle back up at the same time The part with the 2 long grooves in it must go under the flap as you lift handle.
Chris.
http://dysonmanuals.llc.nu/
Jul 07, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
