Question about Dremel Variable - Speed Multipro Rotary Tool 395
Dremel model 395, Type 5
Was using this tool to help my son make his pinewood derby car.  Appears that I 'burnt it out', though don't ask me how I overused it (was just sanding balsa wood).
the unit just stopped working and quit.  thought there might have been some internal fuse or heat sensor that automatically shut it off ... didn't appear to be one.
have read other people's descriptions and 'popped the hood' on it to see if  I could spot anything amiss.  aside from a little fine sawdust, nothing.  I put a vaccuum attachment to it, just to make sure sawdust wasn't preventing electrical contact, then reassembled.
got nothing ... not even a click.
thought my problem might be "brushes", per other people's descriptions, but don't know what brushes look like.
Suggestions?
  • 3 Answers
Brushes are usually conducting carbon sticks at one end of the rotator (spiny bit in middle of motor) there will be two (opposite each other) connecting to the commutator (round copper looking ring with slits in it). The brushes will each have a spring that pushes them onto the commutator and a wire to carry the electricity to the brush.
As the rotator spins, the brushes connect to different coils via the commutator. This allows the electricity to energize the next set of coils to make the motor spin more.
If the motor gets very hot the brushes can stick in their housing and loose contact.
My Dremels (and type) all have the motor cooling exhausts and intakes where you need to hold them. It is quite hard to not block them during use..
I would also get hold of a multi-meter or continuity checker and check that the lead into the motor has not broken inside. Another common problem.
Posted on Aug 01, 2008
How to replace the brushes in a Dremel 395 Type 2?
I figured it out. Use a small std slot screwdriver (not a jewelers or hobby screwdriver, more like the smallest standard screwdriver in your regular tool kit). My Type 2 Model 395 has a couple small tabs. Put the blade of the screwdriver on one of the tabs (shaft of screwdriver perpendicular to the tool) and press downward (not too hard) and toward you (if right handed). The plastic tabbed cover should rotate in towards the tool. That's the brush holder and you are rotating it 180 degrees so that the brush comes to the top. It will take a couple of "bites" of the screwdriver to rotate it fully. Be careful b/c the brush is under spring tension and if you rotate it w/o care it will shoot out (my first one did). Anyway, you should see a carbon brush with a slight arc cut in it if you have any brush left. Hopefully, you have little or no brush and a spring. Then it's easy to replace (my brushes were OK and just re-seating them and my tool was OK). Note that the 90930 brushes sold at most hardware stores won't fit. They are for the Types 3,4, and 5 model 395 (and other dremel models). You need the 90929 brushes for the Type 2. My camera is klutzy. If you can't get it, let me know and I'll try to post a picture or video.
Jan 22, 2012 | Dremel Variable - Speed Multipro Rotary...
Dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Jul 19, 2010 | Dremel 395 Variable Speed Multipro Rotary...
I have a Dremel model 395, type 3 that runs but does not turn the drive shaft. Are parts available to fix?
hello. yes. go to dremel.com and get new brushes for your tool.
ps kindly rate my answer as helpful. thank you. Joe
Feb 17, 2010 | Dremel 300 1/40A "Multi Pro" Rotary Tool...
I own a Dremel model 395 type 5 variable speed and it suddenly stopped working. I was wondering if it was common for the switches to go bad or if it's known for other parts to cause it not to turn on.
I would recommend going to Dremel.com and asking their tech section about this. I have one also and mine works fine other than a small amount of heat at the spindle area.
Jun 17, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Dremel Model 395 Type 3 Plastic Drive Shaft Connection broke into pieces. Replacement needed.
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
Apr 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Dremel Moto-tool model 395 type 1 lock
You can either go to Dremel.com and type in your model number for replacement parts or call their toll free number at 1-800-437-3635 and get that information. Let me know if you need anything further
Feb 20, 2009 | Dremel Variable - Speed Multipro Rotary...
Need new variable speed switch for dremel 395 type 1
Someone else recently asked the same question and got the following solution;
http://www.fixya.com/support/t1515699-variable_speed_switch_dremel_395_get
Jan 29, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
1,864 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
