Question about Sanyo PLC-XU58 Multimedia Projector
How do i read out the lamp hours time on a xu58 from sanyo? is it a button combination?
  • 442 Answers
There doesn't seem to be a menu that shows the hours used.
Posted on Mar 16, 2011
Hi, i have the projector since january 2009, i use it no more than 2 hours a week, sudenly the lamp stupped to work, and when i try to get it on - the replace lamp is flash, what is the prublem?
Was it new when you bought it. (that is, are the lamp hours approximately 220 hours genuine)
take the lamp out and check that it looks OK.
The unit may have an electronic fault on the lamp power supply board.
Mar 26, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Hi i have sanyo xu58 , i cant seem to find a bulb , Will there be any other bulbs that will fit mine?
Hi I have recently purchased Sanyo projector bulbs from avpartsmaster, google them they are based in Bracknell Berks, failing that you can pick them up brand new on ebay.
Good luck.
Ian.
Dec 20, 2010 | Sanyo PLC-XU58 Multimedia Projector
Ive put a new lamp in my Sanyo PRO-x Multiverse projector PLC-SU30 but still not working. I've been told I need to reset the machine by pressinmg a combination of menu buttons - is this correct and can...
I'm having a similar issue wit a Sanyo. Installed new Sanyo lamp but when you plug it in the warning indicators show that there is no lamp detected. Ballast issue? Sanyo tech support told me this is rare. I'm not all that confident about the lamp socket. it seems to be a loose fit. Can't find any info on a reset.
Aug 12, 2010 | Sanyo (6102932751) Projector Lamp for...
Sanyo PLC XU48 Need to know the lamp hours!
press and hold down the power button for about 20 seconds. The info will show in the top right of the screen.
Micketec
May 25, 2010 | Sanyo PLC XU48 Multimedia Projector
What is the lamp life on a sanyo plv-z2 bulb and how to read the bulb life there are 3 numbers that come up when i check it
If I remember correctly, you hold down either the power or the menu button for 30 seconds... I believe it is the power button, and it will briefly display it on the screen, but this assumes it was reset at the time the lamp was installed. The counter counts up on this model, and the lamp replace light will come on at 3000 hours. I have 2 of these units, and I have gotten at least 5000 hours out of each lamp. Toward the end of the lamp life, it may start getting dim and/or have difficulty starting, but I probably wouldn't replace it until you either notice the dimming or the lamp fails, although I've heard some say they can damage the projector when they fail, I have not had any problems.
Dec 03, 2009 | Sanyo PLV-Z2 Multimedia Projector
Is there any way to check the bulb life on a Sanyo PLC-XU30 projector? I know some projectors have an option on the menu screen which lets you know how long the bulb has left. Its just that i bought it off...
on my XU 55 the trick to read the lamp hours is to press and hold down the power button in about 20 seconds when the projector is turned on. there will come a window in the upper left corner that tells about total hours and lamp hours. the window will disappear quite fast, so one might need to do it twice.
Jul 28, 2009 | Sanyo PLC-XU30 LCD Projector
My TV is showing a message on the screen, it says that, I need to change the lamp light for the timer and press this button to stop this message.
These lamps have "lifetimes" that average x hours. The TV keeps track of the use hours and will display the message you see when that time has elapsed. While the lamp may continue to finction, it may not be generating full light output. You should change the lamp as soon as you can get one.
Dan
Jul 25, 2009 | JVC Televison & Video
Flashing red Power light, but unit won't start
I had a similar problem, but with no lcd lights showing and the technician diagnosed as being caused by a faulty Ballast which he said caused the bulb to fail. He didn't test the bulb but his experience indicates that even if the bulb was not blown it would have been stressed and it would only be a short time before it fails completely.
When these fail there is no real reason for it it seems but it has been suggested that a probable cause could be not cleaning the filter, at least every six months. The result of a dirty filter would be overheating and this could be the cause of the failure. Perhaps you will have to check the ballast for problems
Jul 28, 2008 | Sanyo PLC-XU58 Multimedia Projector
Sanyo PLC-XU58 projector completly dead
I had the same problem and the technician diagnosed as being caused by a faulty Ballast which he said caused the bulb to fail. He didn't test the bulb but his experience indicates that even if the bulb was not blown it would have been stressed and it would only be a short time before it fails completely.
Jun 05, 2008 | Sanyo PLC-XU58 Multimedia Projector
How to check lamp hours on xf-45 or xf-35?
On the XF-45, you push the "UP" button and then the "Menu" button and hold both of them for approximately 20 seconds. After that you will see a bunch of numbers in the top left hand corner of the screen. Using the Left and Right arrow keys, move the "Group" number until it reads 111. Then using the Up and Down arrow keys to scroll through each lamp (0-3).
If you move the "Group" number to 110, you can see total number of hours that socket has run.
Jan 22, 2008 | Sanyo PLC XF45 Multimedia Projector
Sanyo PLC-XU58 Multimedia Projector Logo
61 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
