Question about Zyxel P660HW-D1 Router
Have set up wireless router but dont know how to enter and store network name and security code
    Problem Solver:
  • 6 Answers
Power up your router and connect a computer to it. Open your web browser and go to 192.168.1.1 . You should be greeted with the routers login page. The default username would be admin with the password 1234. After you have loged inn, you can start configuring your router and network.
Posted on Mar 15, 2011
Setting up a new modem
After you press the reset. Your laptop has to be physically connected to the router to configure it
Open your web browser, type in "192.168.1.1" and login using username and password.
In "Basic setup" DHCP Server should be "Enabled"
Enter "Domain name" Name your private network
Set the starting IP address - Enter 10 ( any low number)
Set time zone
Save Settings ( button at bottom of page )
Under Advance Routing, set Operating mode as "Router"
Save Settings
WIRELESS TAB
Wireless - set to MIXED
Wireless network name - same as domain name
Select a wireless channel (default is 6)
Wireless SSID Broadcast - ENABLE
Save Settings
Wireless Security tab
Select WEP
Default transmit Key - select 1
Enter a pass phrase to generate a security code, click on Generate
WRITE DOWN THE PASSKEY ( aka, Security code)
KEY 1 should have this PASSKEY entered.
SAVE SETTINGS
On your laptop, right click on the icon for the wireless on the task bar, select "View available networks"
Select your network, it should prompt you for the passkey, you will need to enter it twice
Jan 08, 2013 | Zyxel (91-004-361002) Wireless Router
Tip
How to reset your linkseys wireless router wep key.
Press start on your computer
click network
right click on the router
click on view device web page
leave user name blank
password - admin - ok
click wireless tab
change wireless(ssid) network name (anything will do, it will assign you the correct one) write the name down.
click reset security, wait till it fully uploads
click save settings
when the page reloads click on security mode - wep
enter 10 didgit code, letters and numbers: ie: abcde12345 (write down the number)
save settings
back to network on the start menu
setup connection or network
manually connect to wireless network
enter network name
enter security key
highlight the one you want
click connect
on Jan 31, 2010 | Linksys Wireless-G Broadband Router
I dont know my SSID code
The wireless router has a default SSID usually it is the router manufacrurer's name, you should change this SSID to something different to make your wireless router secure.
Connect a LAN cable from the router to the LAN port on your computer, open a browser and enter the router's configuration URL and go to the wireless settings to change the SSID.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 14, 2011 | Computers & Internet
I dont know how to set up the nintendo wi-fi connection
  1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  2. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  3. Click on "Search for an Access Point."
  4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Once you have done this you may find next to your wi-fi, a lock this is what they mean:
unlocked_g.png No security - Your wireless network is unlocked.
  1. Tap on your network name to select it.
  1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
  • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
  1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
Jul 05, 2011 | Nintendo Video Game Consoles & Games
Some one get into my linksys rouder and set up secrity code and now i can not get into my rouder . so please can you help me get rid of thiold secrity code and so i can set up the newer code so i can use...
If you don't know the password, then you need to reset the router,
Hold it down the reset button with the help of a pen point and power cycle your router. Then re-do the configuration following the manufacturer's instructions. Then you can set password for your router.satheeshd_0.jpg
Nov 05, 2010 | Linksys Wireless-G Broadband Router
My husband bought a dlink router (it says dgl-4500 on it) and i cant figure out how to use it to get wireless internet for my new laptop....i have three "codes" he wrote down- a "router pass", a "network...
Router password is the password to access the router settings.
SSID is the network name. When you try to connect to the wireless network on your laptop, you will see this network name.
If your network is secured network then it will ask you for the network key or the password. You need to enter the ' security key '.
Click Here for step by step by instructions
Sep 11, 2010 | D-Link DGL-4500 Wireless Router
How do I lock my Dell TruMobile 2300 wireless router to keep the neighbors from getting access to my wireless internet connection
press win key + r
under run type cmd
on the command prompt type ipconfig
not down your defaut gateway.
type it in your web browser, and then enter the correct user name and password for the router.(i u dont know the user name leave it blank or try admin for both user name and password or its combination o call dell for it)
Create a unique password on your router : Once you have logged into your router, the first thing you should do to secure your network is to change the default password* of the router to something more secure.
This will prevent others from accessing the router and you can easily maintain the security settings that you want. You can change the password from the Administration settings on your router’s settings page. The default values are generally admin / password.
Change your Network’s SSID name:
The SSID (or Wireless Network Name) of your Wireless Router is usually pre-defined as "default" or is set as the brand name of the router (e.g., linksys). Although this will not make your network inherently* more secure, changing the SSID name of your network is a good idea as it will make it more obvious for others to know which network they are connecting to.
This setting is usually under the basic wireless settings in your router’s settings page. Once this is set, you will always be sure that you are connecting to the correct Wireless network even if there are multiple wireless networks in your area. Don’t use your name, home address or other personal information in the SSID name.
This is sufficient to secure your router from other to use it.
Aug 11, 2010 | Dell TrueMobile 2300 Wireless Router...
Somehow my belkin 54g router is now a secured network and i didnt set it to be and now i cant get a signal because i dont know the security code. how do i put it back to being unsecured?
Please enter the IP address of the Router in the internet explorer and enter the user name and password of the router.(admin, admin). When the windows will open, you can see the wireless security. When you click on that you can see the security key. Other wise you can change the security key.
Aug 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I am trying to connect another computer to my wireless network but i do not know my netgear code, where do i find this?
Netgear code? Can you be more specific?
Are you referring to the password required to connect to your wireless network called "Netgear"? I assume you're being asked for a password on the 2nd computer when trying to connect to the wireless network called "Netgear".
  1. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  2. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  3. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box. This is currently set to "Netgear" most likely.
  5. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  6. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  7. Click Apply to save the settings.
Once you've set this password, you can use it to connect to "Netgear" on your second computer.
Jul 25, 2010 | NetGear WGR614 Wireless Router
My PS3 is asking for a wpa key code so I can go online?
If you dont know your wpa network key try to reconfigure your wireless network again.
Access the configuration page of your router.
>Type on the address bar 192.168.0.1
>On login type Admin leave password blank. if you set up a password or the login page use that one.
>Once inside the Dlink Page
>Clik Setup and on the left side click wireless setting.
>If given the option to click on manaul wireless connection setup click on it.
>Once you have the wireles window
>try to change the network name to a new one and scroll down
>Under security choose WPA security (enhanced)
>Scroll down and under the Passphrase type in your new network password or security key and confirm it.
>Click on Save Settings
>If it asks you to reboot then reboot it, if not, its ok.
Jan 26, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Zyxel P660HW-D1 Router Logo
70 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
