Hi i have a beko wm5101w washing machine and it shakes alot when on the spin cycle i have tryed ajusting the feet but nothing seems to be working to stop it
I had the same problem with the same machine, Theres 4 bolts you have to take out on the back that have gray rubber round then, there used to transport the machine from new but need taking out to use it or they make it shake, it will stop when you remove them
Posted on Aug 17, 2012
    Brigadier General:
  • 6,277 Answers
Although you say you have tried adjusting the feet I would recommend you try my method to make absolutely certain!
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 15, 2011
My beko washing wont do a cycle instead jumps to spin then whilst trying to do a spin it jumps all over the kitchen
Hi if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first. there are a few possibilities here see below
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Aug 21, 2014 | Washing Machines
Kenmore elite ast2 is shaking and moving around on the floor in spin dry cycle.it is level,floor is clean.machine tries to ajust but still jumps around.
Try leveling it. First, put a level on top of it. Adjust one of the two front feet until it is balanced. (The front feet screw up and down.) Be sure you level it in place; don't move it out of the spot where you will use it.
Apr 18, 2014 | Kenmore Washing Machines
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 28, 2014 | Beko Washing Machines
Wme8227b broken?
Possibly blockage in pressure system
Jun 13, 2013 | Washing Machines
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
Washing machine shakes violently during spin
Hi
If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Also check this link bellow:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
May 03, 2011 | KitchenAid Washing Machines
Maytag front loader shakes really loud
make sure the transport tie downs have been removed during installation and that all four feet are adjusted properly so machine does not rock.Also make sure your floor is reasonably solid.
Sep 25, 2008 | Maytag MAH21PD Front Load Washer
Washing Machines Logo
164 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
