Question about Garden
Replacement carburetor for sears 536 796516 - Garden
  • Roy Cagle
    Roy Cagle Mar 15, 2011
    I see it is a 9" edger. We are going to need more info on the engine, so we can go to the manufacturer's site and reference the carb. You may just need a rebuild kit for the carb. We have to determine what carb is on the unit. If it has Briggs engine, post all info listed on the plate. Look around (if still there) and see. Repost and we will try to help. The Sears site only has chassis parts, nothing for the engine.
I installed a 632690 carburetor on my older sears 10 hp riding mower. The mower starts but I can't adjust the speed. I need a diagram on how to connect the linkage
interesting
Tecumseh 632690 - Carburetor
if still original
the sear should have a Tecumseh 11 hp motor
the pictures are the original governor and carby set ups for a sears 10 hp
Oct 18, 2016 | Sears Garden
Sears model 917.288130 cranks but not start. Check fuel solenoid check and can get sparkplug check all 3 safety switch. Recharging battery
If you sprayed carburetor cleaner into the plug hole then reinstall the plug and the unit starts and runs for a few seconds then the problem is your carburetor.
Nov 01, 2015 | Sears Garden
Moter will only run with chock on
This usually indicates that the engine is not getting sufficient fuel. Replace fuel filter. The carburetor may be dirty. Add 1/3 - 1/2 can of carburetor/ fuel line cleaner to the gas tank. Inspect the spark plug. If this does not help, please provide specific info on the mower, brand , model #, serial #, engine # ., which is usually on the engine shroud....
Apr 23, 2014 | Sears Garden
Craftsman 2.5 HP edger 536.797512
You need to have the carburetor cleaned out carefully. Do not lose any parts and put them all back the same way.
May 16, 2013 | Craftsman Garden
How do i get to the fuel filter on an old sears blower model 358 797920,32cc
Sounds more like the carburetor needs to be cleaned or replaced. Dirt in carburetor will cause this problem.
Aug 29, 2012 | Craftsman Garden
Find carburetor on gas blower carftman358.7977920-32cc
Follow the linkage from the fuel trigger to where ever the cable ends and it will be hooked to the carburetor.
Jul 29, 2012 | Sears 25cc 2-Cycle Gas Blower/Vac
Trouble with carburetor,runs after priming then shuts off.sears push mower model917.382730 installed sears kit need soloution.problem occurs every time it is started.have replaced primer kit which works,...
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
After cleaning and before you reassemble the carb, be sure to "set" your float level, turn the carb upside down and make sure the float is LEVEL and not tilting up or down
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Aug 23, 2010 | Craftsman Garden
Craftsman weed eater wont run
MAKE SURE YOU REPLACE THE CARB GASKETS. ALSO MAKE SURE YOU ARE USING FRESH FUEL WITH THE RIGHT MIXTURE. COMPRESSION SHOULD BE AT LEAST 90LBS
Sep 24, 2009 | Garden
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
