Question about Dewalt 18v Dc385 Reciprocating Battery Saw
How do u take off the top of a dc385 cordless sawsal to unscrew the two top screws .. is there any video?
  • 2,176 Answers
There is no video, but you can download a breakdown for this tool at "dewaltservicenet.com" to see what I am going to explain. first remove the battery, and the pivot shoe. Next pull the gearcase insulator off to expose the gearcase housing and then you will have access to all the screws that have to be removed in order to unscrew the top. The gearcase insulator is sometimes "tight" to remove so you might have to pull hard but it will come off. Let me know if you need more assistance.
Posted on Mar 16, 2011
Why the DC385 does not start /
My guess would be either a failed switch or a failed (motor) brush, unless you've been using it REALLY hard and burned up the motor windings. You'd really have to work it HARD to do that, though.
Aug 04, 2014 | Dewalt Tools (DEWDC385K) 18V Cordless...
De walt dc385
should come with a chuck key, or a key to lossen the blade. all of them lock in this manner regardless of manufacture. Check website of manufacture for this, or your mannal
good luck
Apr 30, 2013 | Saws
How to grease dewalt dc385
The grease they recomend is part number 286436-00 at a cost of $80.87 for a 1pound can. I'd call the factory at 1-800-433-9258 and see if they offer a smaller tube.
Dec 20, 2012 | Dewalt Dc385 Xrp 18v Cordless Recip Saw...
Saw is smoking
First I would check to two wire leads coming from the switch to the brushes. They will often melt from too much heat. There is a very good chance that the switch is bad too. Here is the parts diagram. The leads I referred to are items 43 and 44.
DeWalt DC385 diagram
Aug 19, 2012 | Dewalt 18v Dc385 Cordless Reciprocating...
Readers manuel for dc385
you can try going to dewaltservicenet.com and downloading a manual. If you need more assistance let me know.
Oct 11, 2011 | Dewalt DC385B 18v. Cordless Bare...
Blade will not release on sawsall
ok first this is in the chainsaw category and since they don't make one,, I'll assume you mean a sawzall, if you have the quick release ( which is a joke and is a bad part ) your going to have to breal off the blade at the section that it reduces ( where it goes into the holder) unscrew the ringnut that releases the blade, and take it all apart. be careful there is a ballbearing sitting inside there that will roll right out and naturally get lost in the mix. once apart you can remove the last of the blade. Now if your really lucky, you can clean it,, lightly oil this piece , and reassemble it,, and it will work, I have 3 and have replaced that part on all 3 of them,, Now if its an older model that still has the set screw hold down,, Just unscrew the setscrews and remove the blade, ( some have 2 some just one set screw depending on the model
Jul 03, 2011 | Garden
Hi i broke the chuck on my 1/2 makita cordless
Put the biggest hex key you have in the chuck and tighten it then hit it clockwise with the spindle lock engaged a couple of times. The screw in the chuck will then undo clockwise and the chuck can be undone after by putting the allen key back in and unscrewing it anti-clockwise maybe with a light tap from a mallet.
Hope this helps
Jon
Jul 01, 2010 | Makita 6349DWDE 18-Volt Ni-MH 1/2-Inch...
How to open the front housing of dewalt dc385 recipricating saw
press release button and remove shoe on front of saw. Remove 2 screws on front end. Slide off rubber covering. To open gearbox remove 4 screws and pull off. Note, once open yo probably have to replace the gasket. If saw is jammed, try spray a penetrating oil in and tap shaft with a hammer using a wood dowel for contact. You can remove the 2 rubber plugs from the gear casing and pump in grease without removing the cover.
Stephen Brown
Jun 13, 2010 | Dewalt DC385B 18v. Cordless Bare...
I HAVE DC385 NEW. AFTER ONE USE T,THE SWITCH DOES NOT APPEAR TO BE WORKING. ANY IDEAS?
I would take it back and get it fied under warranty or replaced, I believe they have at least a 1 year warranty on their products.
Oct 02, 2009 | Dewalt DC385B 18v. Cordless Bare...
Dewalt 18v  Dc385 Reciprocating Battery Saw Logo
120 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
