Question about Whirlpool Washing Machines
Agitator seems "broken" in half.
  • 59 Answers
This is a two stage agitator there is a one way clutch in the top half if you take off the top of the agitator and remove the bolt holding the agitator and remove the top section you will find 4 dogs in the center replace these and the top half will only turn in one direction.
Posted on Mar 15, 2011
    Sergeant:
  • 170 Answers
You will need a set of adjatator dogs about 5.00 for a set..get them and we will show you how to replace.czerney@msn.com thanks for voting good luck.
PAV2300 agitator bolt keeps coming loose
Loctite sounds the order of the day. Don't overtighten once the thread lock is in place and allow to cure before using machine.
Apr 23, 2012 | Maytag PAV2300 Top Load Washer
The top half of the agitater does not work it just
There are small plastic parts called "dogs" that wear out. The agitator needs pulled apart and those dogs replaced. It is fairly simple to do.
Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does spin but barely agitates
It sounds like the agitator dogs are worn.
To remove the agitator, pry off the agitator cap and remove the bolt that holds down the agitator. With the bolt out pull up on the top section of the agitator (auger) to remove it. Underneath the auger you should see 4 small white or beige plastic gears (dogs). . Replace those and it should be ok.
The part number is 80040
Let me know if you need more assistance.
Apr 08, 2009 | Kenmore Washing Machines
Top half of agitator turns free (does not agitate)
You will need a set of agitator dogs. Pull off your agitator cap and look under it, you will see 4(four)small tabs that catch and release the top 1/2 of the agitator.
Good Luck!
Feb 25, 2009 | Washing Machines
Broken Washing Machine Agitator
probably just what is known as agitator dogs just worn ..with no brand or model i assume it's a whirpool or kenmore ..1st remove softner dispenser (without brand can't say how it would come off ..some twist off some just pull off ) if agitator has cap underneath pull it off in center of agitator should be a bolt 7/16 if kenmore/whirlpool..remove it pull up on top half ..whole thing may come out if so just pull up sharply on top part..center part of top half comes out dogs are on it( 4 )again i'm assuming kenmore/whirlpool whirpool part # 80040 replace them and reassemble ..if any other brand will probably have to replace entire agitator..good luck
Sep 11, 2008 | Washing Machines
The top half of the agitator (near the fabric softner comp) is skipping while it is in wash cycle
yes the top half seperates from the bottom half inside the top half are 4 little parts called dogs. the part number is 241341. replace the dogs to fix it
Nov 27, 2007 | Kenmore 22932 Top Load Washer
Removing agitator
There is a plastic plate in there, must remove it to get to the half inch nut holding it on.
May 31, 2007 | Whirlpool LSR5102LQ Top Load Washer
Washing Machines Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
