Question about RCA D61W20 61" Rear Projection Television
Tv wont power up
RCA 61" HDTV wont power up. push power button light blinks a few times then stops
  • 3 Answers
If you can not turn on TV set with the power button on the TV its not astandby problem as this would by pass the standby. Theres most protec,on a set of this age, top have a poiwer regulator,vertical,horzontal/chcroma problem and is goingto need a trained tech to assist you in this repair. www.afiata.com
Posted on Aug 01, 2008
Rca Tv wont power on HD61W66
Sounds like the capacitors on the deflection power board CP150, CP120 and CP114 they are famous for failing in all versions of the ITC222 chassis. You can get the repair kit by that same name from www.tvrepairworld.com the kit has the caps and the cd with repair instructions
May 18, 2012 | RCA HD61W66 61" Projection HDTV
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power switch doesnt work. It blinks for a few seconds then turns power button goes off all together. Tv wont turn on at all.
Hi jenna;
We need a little more info like Brand, Model # and how many times the light blinks.
Good luck
Buck
Nov 14, 2009 | RCA D61W20 61" Rear Projection Television
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
61 RCA Screen Problems
This is a bad sign of video board backlight going to failure.Make sure u get a warrenty repair,make sure they replace video backlight board.Or exchange the tv.U got a bad IC U could call the CPU for the board.It have intermitent ground sort.U can unplug the power,replug the power,it will work,but this temporally fix only.The high power of the board will kill the IC sooner or later.
Feb 26, 2009 | RCA HD61W66 61" Projection HDTV
I need help with my rca tv
probably bad color wheel. not an easy repair. some of the rca dlp required the light engine be
pulled out to replace color wheel.
Feb 24, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
RCA D61W20 61" Rear Projection Television Logo
131 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
