Question about Dryers
Timer wires crossed. Need diagram of timer - Dryers
  • Dryers Master
  • 8,220 Answers
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
Wiring diagram for Omron off delay timer
Which Omron timer?
The model and wiring diagram appear on side of timer.
Add a comment with more details and I can track down the information.
http://waterheatertimer.org/How-to-wire-pin-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#Omron
Sep 07, 2012 | Amperite Dayton Solid State Timer On Delay...
I have an Intermatic ST01c installed in a 3-way. Both switch and timer operate properly manually. The timer will turn on the lights at the programmed time, but will not turn off the lights at the next...
1) Open following link to compare correct 3-way wiring diagram against your wiring:
http://waterheatertimer.org/ST01C-program.html#ST01C
Blue wire must always connect to the Load (light)
The red wire is designed to reverse the timer. Each time the timer-red wire comes in contact with the timer-blue wire, the timer program is reversed.
So the 2nd 3-way switch is wired differently than regular 3-way wiring.
The 2nd 3-way switch merely connects and disconnects the red and blue wires, reversing and re-reversing timer program, and that's how the timer works for 3-way switching.
And that's why the red wire is capped off when timer is used for single-pole application.
2) Next thing to check is your programming.
I believe you press Mode button until PGM displays and then press on-off to see program settings.
When programming is finished, press mode button to save setting.
Use same link above. Look at step-by-step programming instructions.
Look for conflicts in programming.
For example make sure event1 ON and event2 OFF are scheduled for same days.
Make sure event2 is set.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 04, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Not keeping correct time
You posted under Paragon 4001-00 120Volt SPST timer
1) If timer is not keeping correct time, generally you need to buy new clock motor.
However Paragon is no longer making timers and parts, except for defrost timers.
4001-00 is not defrost timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
2) You probably need to replace timer
Intermatic cross reference shows T101 timer is correct replacement.
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
3) Amazon sells T101 for $43.
This price is a lot lower than trying to find somebody who has specific Paragon clock motor
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
4) Grainger and many other places sell T100 series replacement trippers and motors.
No worry about defunct product
5) Wiring for T101 appears below:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Cross-over wiring is as follows:
Paragon terminal 1 goes to T101 terminal 1
Paragon terminal 2 goes to T101 terminal 2
Paragon terminal 3 goes to T101 terminal A
Jan 27, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
I need a set of trippers for a Paragon 4001 switch timer. Need both "On " and "off" trippers. Can you find some?
Paragon 4000 series timers uses X2772 tripper
Google search x2772 tripper
Frontier Lighting shows they are out.
A couple other places show 56-60 dollars for the tripper
In November 2010, I got e-mail from Paragon saying that Paragon stopped making timers and parts for timers, except for defrost timers. 4001 is not defrost timer.
Intermatic has cross-reference link if you want to buy new timer:
Cross reference shows T-101 timer matches your timer.
Aplus supply sells T101 for $60
http://www.aplussupply.com/intermatic/timer.htm
Amazon sells T101 for 43$ with free shipping over 25$
T101 wiring:
Jan 07, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
I took the wires off the clock/timer to clean the glass because junk got behind it. When I put it all together the clock/timer does not work. It may be that I have two wires crossed. I need a wiring...
I think I worked it out. Black = Neutral. Brown = Live for the two power spades. The four spades for the timer (from the top+ = Red, Orange, Brown then white on the bottom. You will notice that Red and Orange, Brown and White are clipped together. Timer (and oven) is now working perfectly.
Jan 01, 2011 | Ovens
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
Have a paragon amf 4004-71 timer it runs constantly
Paragon 4004-71 is 240Volt timer
1) If your trippers are worn down, the timer will not turn on and off
Google search for X2772 trippers.
2) If your timer dial is not rotating, then timer clock motor is bad.
3) According to e-mail I received from Paragon Nov 2010, Paragon is no longer making timers and parts, except for their line of defrost timers.
4004-71 is not a defrost timer, so it is no longer being made according to Paragon representative.
4) To change timer brands: Intermatic cross reference shows Paragon 4004-71 can be replaced with Intermatic T-104 timer.
Intermatic cross reference link:
Lowes and Grainger and many other outlet sell T-104 240V timer.
5) How to wire T-104
Dec 15, 2010 | Woods Outdoor Photoelectric 24 Hour...
Need connection diagram Thks
The following diagram is for timers with green, black, white, and red wires:
If your timer is different, add a comment with model number.
Manual says:
Timer-black-wire to Hot; Timer-red-wire to Load (lights)
Timer-white-wire to Neutral.
Here's what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push manual override button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 14, 2010 | Woods 59007 Decora Style 3015105 Minute...
Dryers Logo
60 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
