Question about EdgeStar KC2000 Beverage Cooler Commercial
Kegerator is too cold, no matter what temperature setting I have it at (1 thru 6) the temp stays around 33-34 degrees. I would like my beer temp to be around 36-40.
Hi I just got my EdgeStar Deluxe MINI Kegerator. I set the temp to 38 degrees for 24 hours + and all I get is foam. What am I doing wrong? I've switched back and forth from the manual tap and the
the difference between foam and beer is known as 'change of state', also applies to refrigeration equipment, and is caused when pressures drop too radically. While temperature is a factor, you need to consider your pressurization method and settings more. What are you using to re-pressurize your keg as you dispense brew? CO2? Nitrogen? mix? assuming you dispense from the bottom of the keg (feed tube reaching down near the bottom) lowering the pressure should help reduce the amount of foam when pouring. The thing is, even if you pour a glass full of foam, it will settle over time into beer, and you can add to it until eventually you have a smiling glass of amber joy sparkling at you. Go check some of the articles at ambersuds.com.
Aug 11, 2014 | EdgeStar ES TBC50S Deluxe Mini Kegerator...
I have a Danby Kegerator I purchased at Sams Club a couple years ago. The temperature readout said LE at one point and now it will cool down when I first plug it in, but then it warms up to between 50-70...
contact mark pasieka for a repair.... mail in the board and he can fix it and send it back.... if you live in the chicagoland area he is a liscensed for all types of refridgeration, and since he has 2 degrees in electrical engineering he is especially proficient when the issue is electrical in nature...
mark.pasieka@gmail.com
Sep 21, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
The temp guage does not work and when the keg cooler is plugged in it gets down to 20 degrees and freezes the beer. Can this be fixed?
This solution probably costs more than you care to spend on the problem, but you can buy an external temp controller like this one:
http://www.amazon.com/gp/product/B0002EAL58
You run the probe into the fridge and plug the fridge into the controller. Then the controller will only turn on the fridge if it gets warmer than the temperature you specify.
You might be able to find it cheaper on ebay, too. I'm using this on a kegerator and can keep my beer at a consistent temp.
May 10, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
How to make the kegerator colder
From the operators Manual page 14:
http://www.manualnguide.com/dl/20835/
Each depression of the up or down arrow will
increase or decrease the temperature
incrementally by 1º (F/C) until the desired setting
is reached. The temperature can be set between
36-46º F (2-8º C).
Danby Phone:
1-800-263-2629
*Note: the display will flash for 5 seconds from
the time the last button was activated before
resuming display of the internal temperature of
the cabinet.
Feb 05, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
I have a Sanyo kegerator that will not cool enough. I have set the thermostat as cold as it will go and it will only go down to about 42 degrees. What can I look for?
Drop thae stat it's a screw on the left side that controls temp.Don't rush this you don't wnt to freeze your beer. 1,5 turns to the left will take you down to ice cold beer.
Nov 18, 2008 | Sanyo Refrigerators
Whirlpool Beverage Center (WBC127BLS) - Won't cool enough
If you're handy with a soldering iron, it's possible to 'trick' the fridge into cooling down a few more degrees.
Long version:
If you open the door to the fridge, on the right wall near the bottom is a small plastic grate. You should be able to pull this straight out from the side wall. There is a temperature sensor attached to the back of the grate. Unplug the sensor. (The fridge will then give you a very annoying error beep and display "EE" on the readout. Pushing the °F-°C button stopped the beeping.) This sensor will change resistance with temperature. (The lower the temperature, the higher the resistance) I was reading a resistance of about 3700 ohms at 43°F and 2460 ohms at 68°F. Throw in a rough assumption that the response is linear and it works out to almost 50ohms/degree. In order to 'trick' the fridge into cooling down more, you need to drop the resistance. I was aiming for about 6 degrees cooler. Assuming the resistance response was linear, 6 degrees cooler would give me about 4000 ohms from the sensor. By jumpering a 50000 ohm resistor (yes, 50K ohm) in parallel with the sensor, I should get about 6 degrees cooler. I did the soldering, plugged the sensor back in, and ended up about 8 degrees cooler. Two days so far, everything appears good and the beer is cold.
Short version:
Put a 50K ohm resistor in parallel with the temperature sensor behind the grate on the inside right hand wall.
The temperature read out will be inaccurate forever after though. But then, I just want cold beer, my wife wants cold water, and the kids want to play with the cool blue light. I don't care what the number on the readout is.
Oct 03, 2008 | Refrigerators
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Temperature light control (kegerator DKC645BLS)
Not sure u have a problem.. all appliances dont HOLD a certain.. Temp.. They cycle.. come on for awhile reach a temp the shut down.. goes so low the comes back on... the middle of the cycle is the avarage temp... yours being 36 from what you posted
Sep 04, 2007 | Danby DKC645BLS Compact Beverage Cooler
EdgeStar KC2000 Beverage Cooler Commercial Logo
209 people viewed this question
Top EdgeStar Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an EdgeStar Refrigerator Expert? Answer questions, earn points and help others
