Question about Brother MFC 7840W Printer
Black line appears on scanned document - Brother MFC 7840W Printer
    Sniper:
  • 86 Answers
Hi there! When does the black line appears?When you are using the ADF module or when you are using the normal copy glass under the top cover?If the lien is appearing when you are using the ADF open the top cover and clear the little glass from any dust.if the line appears when you are using the normal glass the your scanner unit need cleaning or replacing , for which you are going to need a service help! Please replay if you have any other questions!
Posted on Mar 15, 2011
4 Suggested Answers
EPIJAB
  • 89 Answers
SOURCE: black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Posted on Dec 14, 2007
  • 9 Answers
SOURCE: Black lines when scan and copy documents
It is because coping is not the best way to get a perfect copy on the printer, Try scanning with computer using black and white photo it will come out much better if you are doing a pic. then use color picture.
Posted on Feb 17, 2008
antiochpc
  • 1314 Answers
SOURCE: vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Posted on Jun 01, 2009
I am getting a black line on scanned documents of my HP Officejet 6310 All-in-One Thanks
It would require you to open scanner and clean scanning head unfortunately.
Aug 02, 2015 | HP Office Equipment & Supplies
Black vertical lines come and go for scans to computer and copies
I suspect the Document Feeder is not aligned properly and light is leaking in. You will need to have a technician in to check the alignment of the scanner to see if it needs to be readjusted. random black lines on edges usually indicate light leaking into the scan area.
Aug 28, 2017 | Xerox WorkCentre 3220
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Black vertical lines when scanning on canon mx420
the ocr sensor in the ADF needs to be replaced, I would recommend replacing the whole ADF as a whole.
Aug 10, 2012 | Office Equipment & Supplies
I've cleaned the glass and still have a black line on the image
Scan a document in 300 dpi in full width. Check where the line appears in the image. For example if the black line appears at vertical position say 1900, then it means the dirt is at 1900/300 i.e., 6.3 inches from left. Clean the area thoroughly. Check if any pin had created a scratch in the glass. At different contrast levels, if the line appears different, it is definitely unclean glass. On the contrary, if the line appears constant at various levels of contrast, then it is possible that scan module is faulty.
S. Mohan, India
Aug 04, 2011 | Canon DR 2080C Path-Through Scanner
How do i get rid of a black line that ahows up down the r side of scanned documents, there is no line on the originals
If you are using the Automatic Document Feeder (ADF) to scan, you may need to clean the scanner bar glass.
First test: See if the line appears when you scan on the flatbed. If so, it is probably a hardware failure.
If it appears only when using the ADF, you need to clean the ADF.
HP has a general diagnostic and cleaning procedure here:
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c00846928&lc=en&dlc=en&cc=us&destPage=document&product=391182&lang=ru
Apr 13, 2011 | HP OfficeJet 7310 All-In-One InkJet...
I am using epson stylus tx110 and i tried to scan and copy a document but there is always appear a black on the the side of a paper when it scanned and printed, how can i remove or set it on full image?...
when you are scanning do set the flat bed cover as flat as you can,?? because when you scan a document with the lid slightly open black lines or shadows might appear. also check the settings of your printer.
Jun 02, 2010 | Office Equipment & Supplies
A thick black vertical line appears whenever i
you have a problem in your scanner assembly, clean or replace it
Apr 03, 2010 | HP Officejet 4355 All-In-One InkJet...
Uneven black border showing up on scanned documents
Most scanners scan the whole "bed" not just the document lying on it. Where no part of the document covers the bed usually appears as black.
Normally when scanning you are offered and option whether to scan the whole document or a portion thereof. When previewed, a dotted line appears around the portion the scanner thinks you want, you have to re-arrange that box so that it lies just within the part or the document you require.
Should this not resolve the issue the menu options on
the left hand side of the Xerox web page should guide you to a resolution.
http://www.xeroxscanners.com/en/us/products/DM632/
Mar 31, 2010 | Xerox DocuMate 632 Scanner
Brother MFC 7840W Printer Logo
573 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
