Away mode system disable - Computers & Internet
  • 49 Answers
If you are using Windows XP
start>control panel>power options
Posted on Mar 15, 2011
How do I permanently disable a DEI Automate car alarm on our 1999 Acura Integra.
Just remove it. It shouldn't be too hard, take all the parts and harness out, reconnect any cut wires and wrap any exposed wires with electrical tape.
May 31, 2015 | 1999 Acura Integra
It is stuck in demo mode how do I fix the problem
SELECTED PRODUCT: (change your search)
How to disable the demonstration (DEMO) mode.
Article ID: 42707 ' Last Updated: 03/11/2014
Sony® stereo systems will enter the DEMO mode the first time you power on the system or if you do not operate the unit shortly after turning on the power to the system.
To disable the DEMO mode, while the stereo system is powered off, press the DISPLAY button repeatedly until the demonstration display disappears.
NOTES:
  • Depending on your model, some units have a DEMO button that is used to disable the demonstration mode. If your unit has this button, with the power to the system off, press the DEMO button until the display disappears.
  • If applicable to your unit, setting the clock on your stereo system will also disable the DEMO mode.
  • Using the buttons on a supplied remote control will not disable the demonstration mode.
If model-specific information is needed to complete any of these steps, refer to the operating instructions supplied with the product. Manuals, Specifications and Warranty information for your Sony product is available online.
May 27, 2015 | Sony Audio Players & Recorders
I have an 06 cobalt and recently my car started to suddenly lose power while driving. It says reduce engine power when this happens. If I turn the car off for a minute it'll go away.
This has nothing to do with the Catalytic converter ! Plugged catalytic converters don't go away after shutting off the vehicle !
This reduced engine power has to do with the
Throttle Actuator Control (TAC) System
Reduced Engine Power Mode When the ECM detects a condition with the TAC system, the ECM may enter a reduced engine power mode. Reduced engine power may cause one or more of the following conditions:
Acceleration limiting--The ECM will continue to use the accelerator pedal for throttle control; however, the vehicle acceleration is limited.
Limited throttle mode--The ECM will continue to use the accelerator pedal for throttle control; however, the maximum throttle opening is limited.
Throttle default mode--The ECM will turn off the throttle actuator motor and the throttle will return to the spring loaded default position.
Forced idle mode--The ECM will perform the following actions:
Limit engine speed to idle by positioning the throttle position, or by controlling the fuel and spark if the throttle is turned off.
Ignore the accelerator pedal input.
Engine shutdown mode--The ECM will disable fuel and de-energize the throttle actuator.
Mar 29, 2015 | 2006 Chevrolet Cobalt
I still have the same problem ct mode will not go away on my sc-pt750
You're under the impression that we see an historical thread that connects this request with a previous one. We don't. Start over. Tell us what is wrong and what you've done already.
This previous Fixya post addresses something similar.
http://www.fixya.com/support/t1342919-sc_pt750_screen_says_ct_mode_wont_change
Or is it "CD" mode??
There's a discussion of "CD Mode" on page 16 of the manual.
"If all loaded discs are DVDs, CD Mode does not work.
HighMAT menus and Video CD playback control are disabled.
You cannot turn CD Mode on or off during program or random mode.
If you want to play a DVD, press [CD MODE] again while stopped to cancel CD Mode. (CD Mode is also canceled when you switch the unit to standby, select another source, or change the disc in the play position.)
DVD and JPEG are skipped without being played."
STCT
MODE
Sep 06, 2011 | Panasonic Home Theater System System
My dell inspiron freezes on the welcome page
While there are a number of possible solutions which may or may not work depending on several factors, the easiest to try is to boot to safe mode and run a system restore.
To boot to safe mode:
When you start the system, as soon as the blue dell logo goes away, tap the f8 button. This should get you to a menu from which you can choose "safe mode". It will show a bunch of writing on the screen and should eventually bring you to the login page, login as administrator.
Run system restore:
This varies depending on which version of windows you are running. In XP it is start>all programs>accessories>system tools>system restore.
Other things you can try:
Login as a different user.
Use start>run>msconfig from safe mode to disable startup items which may be causing the problem.
Consider removing recently installed software which may have caused the problem.
Scan for viruses, malware, spyware, ect.
Run diagnostics on the system by pressing f12 on the dell logo and chosing diagnostics.
The worst case scenario to fix a problem like this is reinstalling windows.
Feb 27, 2011 | Dell Inspiron 1525 Notebook
When the CPU switch on, the system running upto 10 minutes. after that the monitor screen automatically off.
Here is artical I found on how to disable sleep mode on a monitor, this would be for VISTA or 7, if you are using XP it's a bit different. ____________________________________________________________ How to Disable Sleep Mode on a Monitor
Your computer monitor or laptop screen will enter sleep mode after your computer remains idle for a set period of time. You can disable sleep mode if you prefer the screen to remain illuminated. You merely need to change a setting in the Windows Power Management properties box.
Difficulty: Moderately Easy Instructions
  1. Click "Start" and "Control Panel".
  2. Click "System and Security" and "Power Options". This will bring up a new dialog box.
  3. Click the menus to the right of "Turn off the Display" and set them both to "Never". This will disable sleep mode.
Read more: How to Disable Sleep Mode on a Monitor ' eHow.com http://www.ehow.com/how_6953659_disable-sleep-mode-monitor.html#ixzz1CiGFFyLk
Feb 01, 2011 | Acer AL1916W 19" LCD Monitor
Disable on-board VGA
you have to get into bios setting to disable On board VGA card man, just restart your system , on the time system getting on press f8 or delete key or any equivalent key to enter BIOS mode , because different manufacture used to have different key to enter into BIOS mode. After you get into Bios mode just look over and go to advance setting to disable On board VGA card.
Good luck ! if you think your problem solved don't forget to rate
Jan 03, 2011 | Mercury P4VM800M7 Motherboard
He message is ANTI THEFT MODE IS ENABLE. When it
try to go to bios by pressing f2 on start ..and after that choose optimal factory defaults from the list ...it will be somewhere there a line named exactly like that ..after chooseing it ..press f10 to save changes..and reboot ...if it set from there it will go away..
Mar 27, 2010 | Acer AL1916W 19" LCD Monitor
Disable sleep mode
For XP: Start>Control Panel>Power Options>Click the options you would like under the Power Schemes/Advanced and Hibernate. Vista may be a little different but it is still under Control Panel and Power
Don't forget to rate this solution with 4 diamonds.
Feb 22, 2009 | HP w1907 LCD Monitor
Disable task manager
You are using a user loging which has limited access to windows.
Logon with user that has Administrator acess. Then you can change the settings
Thanks
Iqbal
Mar 22, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
