My wireless key board just stoped working I can not type any thing on itto the comp. or any where else
  • 961 Answers
First check the batteries. If they are good try pushing reset button on bottom of mouse. Watch you USB receiver and see if it blinks. Next press the reset button on the USB receiver and see if it blinks. Make sure your USB connection is good and if the receiver has been moved prior to the failure, it could be that the receiver was partially blocke somehow or not in a sightline that could read the mouse.
Posted on Mar 15, 2011
  • David Petry Mar 15, 2011
    I meant to say keyboard, sorry. Let me know if you still have problems. You should have software you can accsess that may help with your problem with a error message. Who's device is it(manufacture)? Let me know through "add comment" at end of solution if you're still having problems.
    Dave
The keyboard has stoped typeing, but it works on the guest profile? this problem occured after someone chaged the ease of access settings, and changing it back , the key board stoped type in the main...
Do a system restore to a time before when the keyboard was working. To do a system restore, go to Start >> All Programs >> Accessories >> System Tools >> System Restore.
May 06, 2011 | Samsung N135 Netbook
Tip
Don't have a router and want to connect the two wireless computers with each...
Don't have a router and want to connect the two wireless computers with each other you need to set up both computers to an adhoc mode.If using Windows XP in your desktop computer follow the steps below to configure the wireless adapter to adhoc mode.
Go to control panel> Network Connections> Right click on wireless network then hit properties> Click on Wireless network Tab and removed everything under preferred networks. Click on Add button then type on the Network name SSID "Linksys". Remove the check for "The key is provided for me automatically" then enter the network key. Make sure that you enter 10 or 26 characters on the network key box. You can only set a network in using alphanumeric characters. You can create a network key by using numbers only,letters only or combination of numbers and letters from 0-9 or A-F characters. Put a check mark on the box says "This is a computer-to -computer (adhoc) network." Hit the ok button. Under the preferred networks highlight the SSID that you have set "Linksys"then hit the advance button. Click on computer to computer [adhoc]networks only then hit close and ok all the way out.
You need to do the same thing on the laptop where you have the installed a wireless adapter. SSID and network key should be the same on your network card. It should be set to adhoc as well.
Both computers must have static IP address. For the desktop computer you can set an IP address of 192.168.1.2 and the subnet mask is255.255.255.0. The laptop must have an IP address of 192.168.1.3 and the subnet mask is 255.255.255.0.
From the desktop computer, under network connections right click on wireless network connection then click on view available wireless network. Highlight Linksys then hit connect. Do the same thing on thel aptop. Once they are both connected try to ping each other and see if you will get reply. To ping the laptop from the desktop computer,follow the steps below:
a.On WinXP/2000:
Click Start > Run. On the Open field type cmd then hit OK. On the DOS prompt type ping 192.168.1.3 then hit enter.
b.On Win98/Me
Click Start > Run. On the Open field type command then hit OK. On the DOS prompt type ping 192.168.1.3 then hit enter.
Do the same thing on the laptop but instead of pinging the 192.168.1.3you need to ping the 192.168.1.2.
If you got replies it means that you are already communicating with each other.
If you are getting a low signal you may change the channel on the adapter. Follow the steps below on how to change the settings of the adapter:
For Windows XP and 2000
Right click on my computer properties>click on hardware>device manager>under network adapters right click on wireless-G notebook adapter then select properties>click on the Advance Tab then look channel then change it to 11. You may try to use other channels like1, 6, and 9.
For Windows 98 and ME
Click start>control panel>network>look for wireless-G notebook adapter with a green icon left beside it then double click on it>click on the Advance Tab then look for channel then change itto 11. You may try to use other channels like 1, 6, and 9.
Hope this help everyone.
on Feb 04, 2010 | Computers & Internet
Slow typing and missing letters compaq presario 2100
missing letters ... can be due to dust or sticky keyboard on the keyboard .. check if some thing spilled on the keyboard,,,... slow typing speed can be coz of virus .. may be ur comp is running too slow coz of an infextion or low memory .. scan the comp with spyware terminator free software online available... hope it works if doesnt then try to put some more ram on the board and see... do post the results... tc
Dec 09, 2009 | Compaq Computers & Internet
My 2g iphone has a key board problem. Its lowermost keys (space bar,numeric etc) are not working. I have restored it as well as upgraded itto 2.0.1 but does not work. Plz help email> faizikhalid1@gmail.com
i had the exact same problem with my iPhone
found a great site which unlocks and fixes iPhones IrishiPhone.com
They fixed my keyboard issue for me and upgraded my phone to the latest software too
Hope this helps you :)
Jan 20, 2009 | Apple iPhone Smartphone
Wireless software problems
try going to you device manager, check if your wireless device is there, if it is unpdate drivers and download new version of the wireless adapter from the HP website.
May 14, 2008 | HP Compaq Presario V6000T Notebook
How to install mikomi wireless key board
I bought a wireless mikomi keyboard and mouse on my pc which has windows vista operating software, but the keyboard is not working , no light is showing. lettiesmall
Nov 17, 2007 | Computers & Internet
Logitech s510 keyboard
I had this problem for a very long time as well. Turns out this is an encryption issue. It's off-balance. You need to reset the encryption, and here's how:
On the LEFT side of your wireless keyboard press and hold Ctrl+Alt, and press F12, then release all three buttons. Now push the Connect button on your Wireless Receiver, then the connect button on your wireless keyboard. Now press Esc. Try it. See if it works. It did for me.
Nov 09, 2007 | Logitech Wireless Access Duo Optical...
Wireless on/offswitch
if your wireless adapter is working, go to control panel>network connections, right click on your wireless adapter icon and select enable or connect, if nothing happens then you may have faulty hardware.
Nov 08, 2007 | Compaq Presario 2100U Notebook
Computers & Internet Logo
David Payne
David Payne
