Question about Home
What does the meddage F9 mean. The boiler is Bulex renova. Thanks
3 Suggested Answers
  • 4736 Answers
SOURCE: Hello! Yesterday some "click" sound came from my
The click you heard was the pilot light cutting off. Have you tried to relight the pilot to get it started again? If the pilot will light, but not stay lit, you will need to replace the Thermocouple.
That should solve your problem.
Posted on Mar 06, 2011
SOURCE: I have a RENOVA boiler
You simply do not have enough water pressure inside your heating system and therefore the Boiler will not fire up. On your Control Panel, press the Bar/Mode button to display the system pressure... Then under the Boiler you will find a valve (On ours its a Blue knob), turn it anti-clockwise to let in more water, when the indicated pressure reaches that required by your system (On ours its 1.7 Bar) shut the value (Turn knob clockwise) - Then you can restart the system.
Posted on Oct 07, 2012
I have Electric Ranges the control panel mot working . the light went out and can back on it shows f9
F9 means different things depending on the brand of your range. For example, F9 on a Whirlpool means that there may be a wiring problem while F9 on a Kenmore means trouble with the self-cleaning door latch. Google F9 and your range brand to find out what may be causing it.
Nov 17, 2014 | Kitchen Ranges
I have a RENOVA boiler and on the screen it shows F1 problem. What does it mean?? And what I have to do?? Thank you
Apr 13, 2011 | Heating & Cooling
Mar 05, 2011 | Heating & Cooling
My boiler a renova bulex thema classic gives an error on the display is F9
yeni bir bulex duvar 24kw takip calistirdiktan sonra yaklasik 5dakika sonra pervanaden sesler geliyor
Nov 10, 2010 | Heating & Cooling
F9 CODE OVEN WILL NOT HEAT.
Hi
Thanks for using FixYa. Error F9 means door latch failure. To resolve this issue you’ll have to check the door latch and replace the door latch and/or assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Amana AOES3030 Electric Single Oven
The oven touchpad shows "locked" and beeps 4 times in succession then shows F9
Hi
Thanks for using FixYa. Error F9 in your range means door latch failure and to resolve this issue you'll have to replace the door latch switch or assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 17, 2010 | Amana Kitchen Ranges
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Kemore microwave model number 721.63763300
F9 is an error that indicates an inverter board or magnetron
has failed. With the F9 error cleared, start the oven and
listen for a ticking sound. The inverter will attempt to
'fire' the magnetron 5 times.(ticking sound). If can hear
ticking, replace magnetron. Check owners manual. Part may be covered by limited warranty.
Mar 26, 2008 | Kenmore 62622 Microwave Oven
Home Logo
53 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
