Question about Dell Inspiron 1525 Notebook
I have the Dell Inspirion 1525 laptop and I'm getting a blue screen that says stop: c000021a fatal system error. The session manager failed to create protected prefixes. I have files on this computer that I need, otherwise I would try to restore to factory settings. I do have the discs that came with the computer, so I'm wondering how I can fix this without losing my files.
  • 56 Answers
Try this page
http://support.microsoft.com/default.aspx?scid=kb;en-us;156669
if that does not work, then you will have to pull the hard drive, back up your files and then reinstall windows.
Posted on Mar 15, 2011
    Problem Solver:
  • 10 Answers
To set up Dr. Watson to trap user-mode program errors, follow these steps:
  1. At a command prompt, type System Root\System32\Drwtsn32.exe -I, and then press ENTER.
    This command configures Dr. Watson as the default system debugger.
  2. At a command prompt, type System Root\System32\Drwtsn32.exe, and then select the following options: Append to existing log file
    Create crash dump
    Visual Notification
  3. After the computer restarts from the STOP 0xC000021A error, run Dr. Watson (Drwtsn32.exe).
  4. View the Dr. Watson log to determine what user mode process may be causing the problem.
  5. If the Dr. Watson log does not contain sufficient information to determine the cause of the problem, analyze the User.dmp file to determine the cause of the STOP 0xC000021A error.
    If Dr. Watson did not create a User.dmp file for either Winlogon.exe or Csrss.exe, you may have to use a different tool to generate a memory dump file of the process that fails. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 241215 (http://support.microsoft.com/kb/241215/ ) How to use the Userdump.exe tool to create a dump file Note Follow the instructions in the Knowledge Base article to troubleshoot a process that shuts down with an exception. While you follow these instructions, monitor the following processes to troubleshoot the STOP 0xC000021A error:
    • Winlogon.exe
    • Csrss.exe
    Note Most STOP 0xC000021A errors occur because Winlogon.exe fails. This typically occurs because of a faulty third-party Graphical Identification and Authentication (GINA) DLL. The GINA is a replaceable DLL component that Winlogon.exe loads. The GINA implements the authentication policy of the interactive logon model. The GINA performs all identification and authentication user interactions.
It is very common for certain types of remote control software to replace the default Windows GINA DLL (Msgina.dll). Therefore, a good first step is to examine the system to see if it has a third-party GINA DLL. To do this, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Value = GinaDLL REG_SZ
  • If the Gina DLL value is present and if it is anything other than Msgina.dll, it probably means that a third-party product has changed this value.
  • If this value is not present, the system uses Msgina.dll as the default GINA DLL.
If this error first occurred after the installation of a new or updated device driver, system service, or third-party program, the new software should be removed or disabled. Contact the manufacturer of the software to see if an update is available. For more information about hardware and software vendor contact information, visit the following Microsoft Web site: - http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors) Last known good configuration If the previous steps in this article do not resolve the problem, start the computer by using the last known good configuration. To start the computer by using the last known good configuration, follow these steps:Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  1. Click Start, and then click Shut Down.
  2. Click Restart, and then click OK.
  3. Press F8 at the indicated time:
    • For an x86-based computer: When a screen of text appears and then disappears , press F8. (The screen of text may include a memory test, lines about the BIOS, and other lines.) There may also be a prompt that tells you when to press F8.
    • For an Itanium architecture-based computer: After you make your selection from the boot menu, press F8. There may be a prompt that tells you when to press F8.
  4. Use the arrow keys to select Last Known Good Configuration, and then press ENTER.
    NUM LOCK must be off before the arrow keys on the numeric keypad will function.
  5. Use the arrow keys to highlight an operating system, and then press ENTER.
Notes
  • Choosing the Last Known Good Configuration startup option provides a way to recover from problems such as a newly added driver that may be incorrect for your hardware. However, it does not solve problems that are caused by corrupted or missing drivers or files.
  • When you choose the Last Known Good Configuration option, only the information in registry key HKLM\System\CurrentContro
Posted on Apr 18, 2011
Hi, My laptop doesn't boot up. I got a blue screen with the following error message- STOP: c000021a {Fatal System Error} The initial session process or system process terminated unexpectedly with a status...
Thats known as a blue screen of death. you simply have to put in an operating system CD which is bootable (the one which you are currently using win xp vista or whatever) just boot through the cd ignore the first repair option and hit enter when the option for repairs appears for the second time just hit R and follow the options. you won't loose any data.
Aug 20, 2010 | Dell Inspiron 1525 Notebook
Stop: c000021a {fatal system error}
start in safe mode with command propmpt and type chkdsk /r/f and let the system get scan.
Jan 20, 2010 | Dell Inspiron Notebook
Hi i have a dell inspirion 1525 flamingo pink, and when i start my computer it fails to start and a blue screen flashes and then it starts over again, it does this in a continuous loop please help!!
start your laptop and tap on the F8 key when you start up.
this will get you to the "Advanced startup Items" menu
select "do not auto restart" near the bottom of the menu and press enter.
This will allow the blue screen to stay up and you will be able to get the stop error code. You should be able to find a fix for it here:
http://aumha.org/a/stop.htm
Jan 19, 2010 | Dell Inspiron 1525 Laptop Flamingo Pink
My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
hello there
here is some information that should be able to explain this error and how to fix it ok?
best regards michael
  1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
  2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
  3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
Sep 16, 2009 | Microsoft Windows XP Professional With...
Dell inspiron 1525 laptop
Get a bootable Install CD for whatever version of Windows and re-install windows from the CD drive. (Windows XP Home I imagine). If the laptop won;t boot from a CD you can alter the BIOS settings to allow it. If you don;t care about your documents, do a DESTRUCTIVE install which will wipe your Hard Disk.  Beware if you do a non-destructive install  that if your problems originated from a virus it could still be on your Hard Disk. If you need help with getting the BIOS  settings changed lemme know.
May 17, 2009 | Dell Inspiron 1525 Laptop Jet Black
Blue screen Fatal System Error. How do I get the laptop to work?
damaged OS windows or most commom hard drive failer..
Apr 23, 2009 | Dell Inspiron 2200 Notebook
Blue screen of death.
Try re-seating the RAM (memory sticks) with the system turned off. Clean out any dust from inside the PC, especially on the CPU fan.
Mar 12, 2009 | Computers & Internet
Stop: C000021a (fatal system error).The session manager initialization system process terminated unexpectedly with a status of 0xc000003a (0x00000000, 0x00000000)
Most places will tell you you're boned, but there is the option of using a live cd, such as Knoppix. The following website has a little bit of background on the problem, and how he fixed it.
http://healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-fatal-system-error-with-knoppix/
Hopefully that helps.
May 04, 2008 | Edimax EW-7117U Wireless Adapter
Dell Inspiron 1525 Notebook Logo
448 people viewed this question
Alun Cox
