System wont load cpu fan works ok no p.o.s.t.
    Scholar:
  • 81 Answers
Hi stargazer50,
Remove one memory module one-at-time. Once you find the culprit, replace it with a good one or work with less memory.
Hope this helps and good luck.
Posted on Aug 01, 2008
My cpu overheated and now my video,keyboard,mouse,and usbs wont work! Whats wrong with it. Do i need a new fan?
Why did it overheat? In cases where a CPU has overheated, it more likely you will need a new CPU. If you can get one. Does the fan run? Is there dust in or around the heatsink? Have you booted the PC? If so, does it start to boot? Does the operating system load up? Anything displayed on the screen? Any errors on bootup? Rgds, Dave.
Mar 04, 2014 | Intel DQ965GF Motherboard
CPU Fan Failure
ask the Dell support of directions, they will guide you.
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
Cpu fan works, power supply fan works why wont' computer come on?
Could be a number of reasons:
The CPu fan and the PSU fans will come on, even though the system is not working. There is a possibility that the CPU has blown, you can check this easily by (carefully) feeling the heatsink after it has been running a while. A dead CPU will not use power and therefore not heat up. If after say 10 minutes of running, the heatsink is clay cold, suspect the CPU. Replace with another one, spreading CPU grease on the top before putting the heatsink back on.
A blown CPU will usually be indicated bu there being NO beeps from the system (see below)
If the CPU appears to be generating heat, visually inspect the board, look for blown or blowing capacitors (the small cylinder like components) on the motherboard, any that are bulging or leaking a brown residue, or have blown, will render the motherboard inoperative.
If these appear ok (they still may be damaged), unplug all components except the hard drive, and ram and video card, see if the system then boots. If it does, proceed to re-installation of each in turn, until the faulty peripheral halts the boot.
Listen for any beeps as the ssytem switches on these beeps describe the type of problem
(repost if you hear any beeps)
Remove one stick of ram and try rebooting, if it works, suspect the ram module, try the other and see if that makes any difference.
Failing that, your last recourse is to power the system off, remove the bios battery, replace after 2 minutes and see if clearing the Cmos "unsticks" the computer.
After That, suspect the motherboard is dead.
Apr 25, 2011 | Computers & Internet
(1)cpu fan error (2)chassis intruded (3)fatal error.....system halted
The reason for this error is Overheat! Please replace the CPU Fan with a new one and add additional Fan for the CPU Cabinet in order to cool the CPU. Then, reset the BIOS to default value by pressing the F2 Key or Delete Key at the Startup and select Load Optmized Defaults or Load Fail Safe Defaults option. This should resolve the issue.
Mar 02, 2011 | Computers & Internet
I HAVE ASUS P5KPL-AM IN MOTHER BOARD MY SYSTEM IS ON BUT I DONT FIND DISPLAY IN MONITOR. MY RAM IS OK, MY PROCESSOR IS OK BUT I DONT FIND DISPLAY ON MY MONITOR .
if you have your monitor light flashing or the cpu fan is working when you on the system try this,
you just need to load the BIOS to its defaults, to do this you need to open the CPU case, unscrew the two screws on the left side of your cabinet, on the motherboard you can see a small button sized battery, remove it and after one minute replace it into its position.
close the cabinet and start the computer it'll work fine....
Sep 06, 2010 | ASUS P5KPL-AM SE Motherboard
When I connect 2nd and 3rd hard disk my system wont starts......
Just because it has a CPU, it is not a brain
It is ok to set up 2 or 3 harddrives BUT... make sure one is a master, (C:)the others are slaves D-Z
Look at all drives, most now have jumpers and they are master,slave,cselect.
To make it easy, slaves/masters
Jul 24, 2010 | Intel D915GAV Motherboard
Computer had a high pitched noise now wont load up only the mouse is on screen
hi
check your CPU fan if its OK
its may be your hard disk sound
sometime power supply fans
May 29, 2010 | Computers & Internet
Mobo giving startup problem!
you have to narrow down the issue.. is it with the pc? or monitor? if you think the cpu... is the power supply fan working? is the cpu overheating? if you think its the monitor...be sure the card is seated properly and check all cables
May 30, 2009 | Intel D845GVSR Motherboard
MLTIPEL PROECESS EROOR
sounds like your fan on your cpu is almost taken a dump common prombelm you better change it before it over heats and takes your cpu out ... lala linda
May 14, 2008 | Dell Delta Electronics CPU Processor Fan...
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
