Question about Coleman Powermate Powermate 5000W Generator
WILL NOT TURN OVER OIL FILL A PULL START - Coleman Powermate Powermate 5000W Generator
    Problem Solver:
  • 11 Answers
Sounds like you may have oil in the cylinder. This is caused by engine tipping over or maybe the generator fell over on its side, etc. This ends up making it really hard to pull start the engine.
Anyway, try removing the spark plug (make sure the ignition wire is pulled out of the way) and then turn over the engine a few times (5 or 6 times) to get any oil out.
Then replace the spark plug and try again to see if it starts.
Posted on Mar 16, 2011
I AM NOT ABLE TO START A BRAND NEW STRAMM GENERATOR
first off---- have you put oil in the sump to the correct level there is a low oil lever switch which will not allow spark if the oil is not there or is too low to safely run the engine
next fill the tank with the correct type of fuel
turn on the fuel tap under the tank
put the choke lever pull in the choke position
switch on the ignition switch
pull the starter cord
when it fires push in or remove the choke action
basically read the user manual that came with the genset
Jul 08, 2016 | Cars & Trucks
I changed the oil in my 2001 jetta and i put in to much now car doesn't start
You're going to have to drain out the oil and put all fresh oil in. Depending on how much you over filled it, I'm surprised it would turn over at all. When you over fill a motor, you put it into hydrostatic lock. Trying to start it can either burn up your starter motor, or break a number of items inside the motor. The reason I suggest to put in new oil is because the oil you drain out will have particulates in it that it picked up from the motor internals; the oil filter should be fine. Once drained, fill with 3.7 quarts, run it for a couple of minutes, turn it off, let stand for 5 minutes, and then check your oil. Make sure you're on level ground when you do this; and don't take the first read when you pull it out. Pull out the dipstick, clean it, put it back in, pull out and then read it. Hold the stick in a horizontal position when you read it. If low, add a little, wait, check it again, you want it to read in the safe zone marking; the 3.7 without filter should be very close to safe.
Jun 29, 2014 | Neuspeed 2001 VOLKSWAGEN JETTA 48.10.05...
How to start Echo ppt-266
Fill with correct fuel/oil mix. turn switch to I. Pump primer bulb 4-5 times. Turn choke on. Pull starter until engine fires. Turn choke off. Pull Starter until engine runs & allow to warm up for 10 secs before trying to engage throttle. If it doesn't start after 3-4 pulls with no choke then try same sequence again. May have to use 1/2 choke after engine fires. If it still won't start then something is wrong with it & it will need to be checked by a service agent.
Jun 19, 2014 | Echo 12 in. 25.4 cc Bar Telescoping Gas...
Start up instructions for PM05450-07.02
check the oil level fill fuel tank with fresh fuel open the shut off valve on the bottom of the tank put choke on and turn the kill switch to the on position and pull the rope release choke after i second pull alway shut the fuel off and run the carb out of gas when done using it
Sep 03, 2012 | Coleman Powermate 6250
Over fill oil
DRAIN OUT AND FILL CORRECT AMOUNT THEN START AND RUN FOR 2MIN AND SHUT OFF PULL OIL STICK WIPE IT OFF AND RE-INSERT AND THEN PULL AND RE-CHECK LEVEL.
Sep 01, 2012 | Suzuki Forenza Cars & Trucks
How do you remove the valve cover oil fill tube on 1997 chevrolet tahoe
you have to turn the tube counter clock wise to unlock it then pull it out
Feb 21, 2012 | 1997 Chevrolet Tahoe
Where is the location on a 1994 honda civic ex that i would fill the manual transmission with gear oil?
Manual transmissions have a fill plug and a drain plug on the side of the transmission. The fill plug is a little above the drain plug. Pull the fill plug and fill the transmission until the transmission fluid just barely seeps out and re-plug the transmission. That is the proper way to fill it. You will need a long stem funnel to give you the room you need to fill it. Your transmission requires a 10W30 weight motor oil, just like your engine. If you have a little time and 3 or 4 quarts of oil laying around you can pull the fill plug first and THEN the drain plug and let all the oil drain out. Then plug the transmission and re-fill it with fresh oil and this is a transmission flush for your transmission. You just saved $70 shop charge doing this. I say pull the fill plug first and THEN the drain plug because the last thing you want to do is pull the drain plug first and then find out the fill plug has welded itself and won't come out and now you can't fill the transmission. Fill plug first always.
Regards, Tony
Apr 17, 2011 | 1994 Honda Civic
Instuctions on how to start mcculloch generator 1800 w
I have one.. great little unit.. very reliable..
I am a wannabee diy guy.. so good luck
1 assuming sparkplug is good / in / /newish??
Fuel needs to be filled.. I suggest premium only (less residue if it sits for long.)
fill oil.. top up..
d/c electric plugs
then
togle ignition switch to on
turn fuel cap to on
turn fuel switch (sw) to on
move choke to start if engine is cold start.
pull starter cord ..
good luck
ps.. I have learned to run engine dry of fuel after use. turn off fuel (sw).. this empties carb.. You may have to pull starter cord a few times with next start to bring the fuel down..
Sep 24, 2010 | McCulloch 2000W Inverter Digital...
I have a 1985 s10 blazer .. i drained the oil and replaced the plug, and replaced the oil filter .. however, i am unable to remove the oil fill cap. it does not pull out nor unscrew .. it does hand...
If you have any other fittings on the valve cover (pcv valve, breather tube etc) you can put a hose into the valve cover through that hole and fill it. (slowly...most have baffles inside). I have seen engines filled through the dipstick tube also (takes forever though).
Once you get oil in there, bring it to a shop and have someone show you how to get the fill cap off so it is easier next time.
Feb 23, 2010 | 1985 Chevrolet S-10 Blazer
Coleman Powermate Powermate 5000W Generator Logo
142 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
