Question about Stanton C.504
CD 1 no disk "message" = no detect cd no
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 92 Answers
Clean it with a cd cleaner or take it apart n clean the eye with a Q tip gentley
Posted on Mar 16, 2011
When trying to copy the message reads source disc empty
Does the disk drive play the disk? If not, the drive could be faulty. If not, then the disk can bec copy protected
Jun 13, 2014 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
SYSTEM WILL NOT READ CD OR DVD
Sounds like the deck needs to be replaced. If you contact Bose, they will usually give you a flat fee quote for the repair.
Mar 17, 2013 | Bose 3·2·1 II System
Not seeing new hard disk or reading XP cd-rom
It can use any 31/2" IDE hard drive. 30 Gb should be OK
If the BIOS cannot detect the hard drive or the CD drive then the drives maybe faulty or the disk controller in the computer is faulty.
Apr 29, 2012 | IBM ThinkPad A30 Notebook
At first my computer cant detect my Maxtor HDD. but when i connect the sata port as a slave , it can detect the HDD. but after that it is showing " Disk but failure...." or " Disk read...
Restart the system and then press delete key when the computer start up then set the first boot to CD/DVD ROM then press F10 (save) and follow the instruction "press any key to boot from CD/DVD ROM after that First try to repair and if it's not satisfy. Please to format your Hard Disk
Hope it'll be helpful to you
All the Best!
Jun 30, 2011 | Gigabyte GA-945GM-S2 (0818313003065)...
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
I CANNOT LOAD WIN7 I cannot get my system to boot from a CD disk (Win 7 Ultimate) I set the BIOS to boot from a CD device - the priority is set for CD first. All other values are default. In...
try to reset bios if does't work try using a usb dvd drive (external dvd drive) remember you do not will be able to read a dvd CD(WINDOWS 7 CD) using a cd burner.
you will need a dvd drive.
Feb 07, 2011 | ASUS Computers & Internet
My fukuda dvd player won't play any dvd or cd.It always show the "no disk " error even if there is already a cd/dvd inside.Already remove the top cover and saw that the disc is spinning but will...
Either the spindle motor is not reaching the required speed to read the table of contents, the traverse motor is in the wrong place and won't allow the disc to be read or the laser is faulty.
It could be any combination of the above. Time for a new player?
Feb 04, 2011 | Televison & Video
I have been using HTS545032B9A300 320GB drive in my Samsung R428 laptop. One day, suddenly, its shuts down and never boots up. It never gets beyond setup. It hangs and showing "Entering into...
When start your laptop,is their any spinning sound in your hard disk(Hitachi)?
If so, try to go setup the bios ,just watch the laptop either detect or not,
If your laptop detect the hard disk ,again install to the laptop, and remove the new seagate just for recover the data through following step.
Please download hiren boot bootable ISO file ,
Download the iso file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Mazor problem is most of the user, burn ISO file in data mode and the result, it could not run in boot time.
Burn the iso file, under image burning option from any nero .
Boot from cd, no need to setup bios.
DONT PANIC follow all the steep It is very simple. (Use the down arrow key.)
1.INSERT CD TO CD TRAY
2.Boot from cd
3.Select start boot cd
FOR REPAIR THE HDD DONT PANICI
Choice hard disk tools
1.select HDD regenerator>enter
wait create it auto mode
2.Enter(If you have one HDD)
3.Press "1"ENTER for scan and repair (With out lose any data)
4. press 3 for REGENERATE ALL SECTORS
I will sugest press for "1" and enter
press( 1-9 )any one number and type mb and ENTER
Repair will Start soon.
Insert a pen drive
Restart your laptop and boot from cd
1.Boot from cd
2.Select mini windows
3.you can explore every drive (hitachi) and can copy paste to pen drive.
ALL IT WILL BE POSSIBLE IF YOUR HDD CAN SPIN AND AND READ .
Hope this helps.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 18, 2011 | Hitachi Travelstar 5K500.B...
Hi there! Yesterday I was installing Windows XP
Sorry to hear your having issues installing the OS.
There is two problems your facing one is the disk is so scratched that the system can not read the disk or the hard drive has bad sectors or clusters which are failing when being written to.
You have two options to fix this one is to make sure the cd is clean an or replace your hard drive.
General disk read error message tend to be from hard drive cylinder's.
Nov 05, 2010 | ASUS Computers & Internet
When i install fifa 10 or fifa 08 my pc show a problem that, it cannot read the group1.cab file. and then show the error code is 2350
that is basically a disc error. it means that the file named in the error message (.cab) file is not recognized or simply the system cannot copy and extract files from it to complete the installation.
resolution:
Create a folder in your local disk and name it Disk-1 then copy all the files of your cd-installer to that folder. do the same for DIsk 2 and so on. When during copying of files to your local disk produces error like "cannot read from device", it means that the source cd is defective with scratches and you need to buy a new installer. when no errors are detected, then open and run the setup.exe file in Disk-1.
Oct 15, 2009 | Computers & Internet
Stanton C.504 Logo
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
