Question about Hitachi Travelstar 5K500.B HTS545032B9A300 Har - 0A57913-20PK 320 GB Hard Drive
When installed the HDD spins but the PC does not recognize the HDD. Not in BIOS, not thru the DOS-prompt or in sys configure/hardware or HDD configuration. It also interfers with the startup of the PC and its performance. This problems is in reference to the: Hitachi Travelstar 5K500.B HTS545032B9A300 Har - 0A57913-20PK 320 GB Hard Drive
  • Hitachi Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
Posted on Mar 15, 2011
Toshiba a215 bios password then prompted for hdd password space bar enter didnt work
BIOS passwords can be reset or removed in two ways:
1. using software 2. using hardware.
I would first try resetting or removing using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html&act=down
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Jul 27, 2012 | Computers & Internet
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
Stack overflow at line 598
Stacks are reserved memory that programs use to process hardware events. A stack overflow occurs when there is not enough space in memory to run the hardware interrupt routines. To resolve these behaviors, you can modify the "STACKS=" line in the Config.sys file, eliminate terminate-and-stay-resident program (TSRs), and eliminate hardware conflicts.
When Windows delivers an error message that is related to an internal stack overflow, there is not enough space in memory either set aside or available to handle the calls that are made to the computer hardware. There are several things to consider when you troubleshoot this behavior:
  1. The Config.sys startup file may not be properly configured for the Windows installation. Use the following values: STACKS=64,512 ;(this is the maximum allowed)
    FILES=60
    BUFFERS=40 If you are using the dual-boot capabilities in Windows, the Config.sys and Autoexec.bat files may not contain the correct configuration to run Windows. When you are dual-booting between Windows 3.x and Windows, these files may not have been renamed back to Config.dos and Autoexec.dos.
    Examine the Config.sys file to determine if files such as Himem.sys or Emm386.exe are loaded from a folder other than the Windows folder. If so, boot Windows by using the Safe Mode Command Prompt Only option. Rename the Config.sys file to Config.dos and the Autoexec.bat file to Autoexec.dos, and then restart your computer.
  2. Some TSRs may be interfering with Windows. Disable any non-boot device drivers in the Config.sys and Autoexec.bat files. If you install from Windows 3.x and you receive a stack overflow error message, check the Win.ini and System.ini files for non-Windows-based programs or drivers that are loading.
  3. There may be an incompatible hardware configuration. Check the port and IRQ settings of the network adapter, sound card, and modem. Make sure that there are no COM2/COM4 or COM1/COM3 conflicts and that no devices are sharing IRQs. Disable or remove conflicting devices.
  4. The computer may need a BIOS upgrade. Check the BIOS version and contact the manufacturer of your computer for information about a BIOS upgrade.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 28, 2010 | Microsoft Computers & Internet
Can't see HDD on boot BIOS does not see any HDD. only wants to boot from a networked sys to get os. How can I change the BIOS to recognize a drive with XP installed on it, without a boot disk. Pg. 2 in...
If the BIOS doesn't recognize the drive then there's a problem with the drive itself.
You'll need to swap it out with a new one. I'd recommend hooking up the old drive to a usb enclosure to double check whether the drive works or not.
OR you can just swap it out with the new one and reinstall the os.
Let me know if you have any questions, I specialize in data recovery ;)
Oct 14, 2010 | Toshiba Satellite A55-S326 Notebook
Asus will open the bios page with F2, but wont boot
I wouldn't quite yet. Here's a solution that should fix this...First, I'm assuming that the BIOS is recognizing the hard drive in the first place? The BIOS should have a utility option to "auto-detect" the hard drive. If it does, then you most likely have a corrupted MBR (Master Boot Record).
Here's my advise: Obtain a DOS-disc (windows 95 installation disc would do just fine) and once at the DOS command line at C: type the following command after the C
C: fixMBR (then hit enter)
this will move the MBR from sector 0 to the next available sector - 1.
Now install the windows installation disk that came with the computer and perform a "repair installation"
It will load all windows sys config files and boot files. It will seem as though you are totally reinstalling windows but you will not.
At first, you follow the simple onscreen prompts to install windows and when you get to the point of entering R for repair...you don't want that yet...continue with install. on the next screen you will see a prompt for a repair installation - this is what you're after. Do not format any partitions and you'll be fine. If you cannot locate a dos disk, here's a link to download one and burn on a CD:
http://majorgeeks.com/Ultimate_Boot_Disk_NT2K_d518.html
Best of luck!
Jan 02, 2010 | ASUS Eee PC 900 Notebook
Balance - Blue Screen during shut down stop error 0X0000007E
check your hardware settings it could be the codes for the hardware that cannot recognize of your systems. it could be change with the wrong specs. if you cannor configure it out. you better set the bios configuration to default setting and try to repair the system using your operating system cd installer. thanks
May 11, 2009 | Computers & Internet
HP Pavilion ze5500 - Laptop won't recognize hard drive.
Hi. Once I had this similar problem with a HP Pavilion dv9000. "No Operating System"; "Windows Recovery Console cannot continue because there's no HD present..press F3 to Exit". No progress with Safe Mode nor Command Prompt, etc.
Then I went to the Bios, change tab to "System Configuration" and change the "Sata Native Support" to disable, whitch says that by changing to disable the HD would work better if the Operating System are Win2000 and Win9x.
Hit "Safe and Exit" and the computer started normaly!
I relly don't know how or why. It just work.
I don't know if would work for Linux (mine had Windows XP) and don't know the Bios view of your laptop. But you can explore and give it a try.
Hope this helps.
God Bless You!
Jan 06, 2009 | Computers & Internet
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Hitachi  Travelstar 5K500.B HTS545032B9A300 Har - 0A57913-20PK 320 GB Hard Drive Logo
301 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
