Question about Sunbeam 2350 Heritage Series Mixer
Sunbeam Mixmaster Heritage model Tilt mechanism failed. I got the bowl out and the beaters but can I fix the tilt mechanism?
Theory: Its a screw at the joint that is lose.
Problem: If I held mine upside down it released but wouldn't when right side up.
Partial solution (in progress): It took me an hour to disassemble the monster as I lost the "NUT" inside the motor - the nut is inside the motor case and attaches the lock-lever and a ground wire to the motor case. It makes some sense since it is a part that can strip out if it has to be tightened too many times by a gorilla - a nut is "easy" (relatively) to replace. Prevents you from having to buy a new one at least. Wish they would engineer this better.
Current status: I finally fished it out but have to put it back together now to prove my theory. You cant get into the motor case easily - but I found out that you don't have to get into the motor case if the screw is still semi-attached. I only had to undo the the base to get to the hinge. Then I could tighten the screw. I am an AMATURE - so at your won risk. They make these things so you need to send them in. This most likely seems to be what I have to do now.
Posted on Sep 25, 2011
Sunbeam stand mixer won't tilt back down
I'm in the middle of a bake sale. Not a good time to send back. Also, I think you meant a free Upgrade at no additional cost...
Dec 14, 2012 | Sunbeam 2346 Heritage MixMaster Series...
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
I can't get the tilt release to release to raise the mixer . I have a batch of cookie dough in the bowl and I am unable to raise the mixer
Try running the mixer for a few seconds to clear anything out from under the beaters, like a chocolate chip. You can also try pushing down on the beater end of the mixer, press the button and lift.
Nov 01, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Motor head will not tilt back
Push down slightly on the head and then the button will go in further and the top will release. ((this answer after I just bought it home and was about to take it back to the store!!))
Oct 11, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam Heritage Mixmaster Won't Tilt back
Hi
Most of them have a button to push that releases the mixer head to tip back. Sometimes the buttons stick and will not release. That picture looks like you are using the Heritage model.
You have to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; tighten it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer you may also notice that the tilt release had become easier to use -- previously you may have found that you have to press the tilt release button very hard to get the tilt to unlock.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Jun 12, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster jammed, will not tilt back
That picture looks like you are using the Heritage model, which is the one I just fixed for myself.
I had to remove two parts in order to get access to the piece that was causing the problem:
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; I tightened it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer I also noticed that the tilt release had become easier to use -- previously I found that I had to press the tilt release button very hard to get the tilt to unlock.
I hope this helps!
Dec 28, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
Sunbeam Mixmaster Heritage series
I hope this helps. I found on mine that the rear screw on the "neck" had become slighty loosecousing the release to not fully disingage. I had to remove the dome shaped cap in the middle of the speed control knob, pops off fairly easy, to gain access to the nut to tighten it. Hard part was trying to hold the screw head still while I used a small screw driver and small hammer to tap the nut tight, very limited space between the "neck" and motor body.
btsctn
Jun 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam 2350 Heritage Series Mixer Logo
290 people viewed this question
Top Sunbeam Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Tony Vallette
Tony Vallette
Level 1 Expert
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
