Question about Frigidaire Refrigerators
The evaporating coils freezing up. - Frigidaire Refrigerators
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
2 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
The coils jeep freezing up I have cleaned the filter
usually means Freon charge is low, you might have a leak..... also, filters don't catch everything. over time what gets past the filter can be trapped in underside of the evaporative coil on top of your furnace..... outside condenser coils may be caked with debris, improper air flow threw coils can produce liquid Freon back to evaporative coil causing it to freeze..
hosing the condenser down will resolve freezing up too
Oct 04, 2015 | Filter Heating & Cooling
Coils freeze up and fridge runs all the time till I melt coils.
There might be a few causes
Door Seal might be defective causing the door not to shut tightly this causes air from the room to get into the freezer through the opening and as the air comes in contact with the evaporator coils, it freezes. Normally the defrost system removes the ice but if the seal is defective the coils freeze too quickly and the defrost system cant keep up
If the freezer evaporator coils ice over, the defrost thermostat might be defective. Several times a day the defrost heater turns on for a few minutes to melt away any frost that may have accumulated on the freezer evaporator coils. In order for this to work, the defrost thermostat has to sense that the coils are cold enough. If the coils are cold enough the defrost heater will turn on. If the thermostat is defective it may not be able to sense the temperature of the coils and then won't turn on the defrost heater. If the defrost heater doesn't turn on, the evaporator coils ice over and eventually no air will be able to travel through the coils to provide cooling to the freezer. The defrost thermostat can be checked for continuity. It should have continuity when it reaches the low temperature of its operating range.
Jun 03, 2015 | Refrigerators
The fridge keeps freezing over
The evaporator coil is freezing, there could be a number of reasons.
a) drain line is clogged... defrost the fridge and shoot short bursts of compressed air into the drain to clear the clog
b) the defrost sensor on the evaporator coil is faulty... replace the sensor
c) the freezer is so PACKED as to impede air flow... stop stuffing your freezer
d) the defrost timer, defrost coil, etc. is faulty... replace as required
You could defrost your evaporator coil by turning off the fridge for several hours with the doors open, blow dryer, heat gun, etc... depending on skill level
Feb 27, 2014 | Refrigerators
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
Why does my ac freeze up
Hello, air conditioners will freeze either due to low airflow.....such as dirty filter, dirty evaporator coil, weak or not running blower motor. Also, a low refrigerant charge can cause the unit to freeze up.
Jul 09, 2012 | Danby Heating & Cooling
Top coil is freezing up, the remaing coils are not getting cold.
low on freon or plugged to the point of where the frost stops on the evaporator. Evaporator should fully frost up on all coils...
Sep 12, 2009 | Kenmore 64802 Top Freezer Refrigerator
Evaporator coil freezing, replaced main control
Aug 05, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Build in kitchenaid, freezer working but not freezing
This video I made how to change evaporator on Thermador refrigerator, which is just copy of of Build in Kitchenaid. Problem was that it was running, but ice cream never got frozen. I checked pressures, was low on freon. I checked evaporator coils - found out that defrost heater got deformed and was touching evaporator coils - so it burned holes, where freon started to leak.( I think it designed not best way). Defrost heater on this fridges way to close to evaporator coils. Check this video to get an idea what Im talking about. I hope That helps u to understand why this repair is so expensive and what causing it.
May 08, 2009 | KitchenAid KSCS25FKSS Side by Side...
Unit freezes up when nearing 8-12 degree superheat
check to see if your evaporator coil needs cleaning
Apr 29, 2009 | Goodman CLJ30AR32 Air Conditioner
Refrigerators Logo
48 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
