Question about Miele Novotronic H350-2B Electric Single Oven
How do I set the clock on the Miele oven? - Miele Novotronic H350-2B Electric Single Oven
    Sergeant:
    Champion:
  • 239 Answers
  • 99 Answers
I don't believe this model has a clock feature - just cooking timer. I checked through the operation manual and did not find any indication of a clock function. The manual is available here:
http://www.mieleusa.com/manuals_pdf/Residential/Ovens/H350-2_us.pdf
Posted on Mar 15, 2011
2 Suggested Answers
  • 354 Answers
SOURCE: how do you set the
Just play with it or go to the manual or support site online
Posted on Feb 15, 2011
I have a Miele H383BP-KAT oven. For some time the clock has not been able to be set. It keeps flashing 12:00 but hitting the arrows to change the time has no affect. Any help would be appreciated.
Just had the same problem with my Miele H383 oven clock. In my case the root cause happened before the power outage. It was a bad connection between the clock printed circuit board (pcb) and the main control pcb .I only discovered it when I couldn't reset the clock. So what appeared to be a serious fault after the power spike was fixed by simply moving some wires (gently).
The wires concerned are the small black loom which go from the back of the clock to the edge of the main board in the top of the oven. There are 16 of them into one connector that fits on the front edge of the main board.
To access this you need to remove the top cover immediately behind the oven control panel. There are only two screws which may have Torx heads but you will prob. get them out with a flat head screwdriver if you try hard enough .If your oven is mounted underneath worktop you probably won't need to take it out completely to do this but take care it doesn't tip or slide out.(remember there are up to 4 small wood screws, accessed by opening oven door, that secure oven to the housing).
The next step requires you to be aware that mains voltage is present around the main control board and the main rotary selector switch so keep your fingers out of this area.
With the power on press the two outer clock setting buttons (as per normal clock setting) and at the same time wiggle or manipulate the 16 wire loom coming from the back of the clock. Try it in all sorts of positions. I was lucky and had success after just a few attempts. I also removed the clock complete with the 16 wire loom and checked the continuity of each wire from main board edge connector to the clock pcb but I could not find a problem So there may be poor soldered joint on the clock pcb which makes and breaks as I move the loom around. Whatever, I am happy again and have saved a lot of cash!
p.s Have your vacuum cleaner to hand and clean the dust out the inside whilst you have the lid off. Good luck.
Nov 09, 2011 | Ovens
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
How do you set the clock on a miele deluxe h 818 oven please
Feb 15, 2011 | Ovens
Miele H 5240 B CS oven Purchased E & S Trading, Ashburton, 1 October, 2010 When I press the arrows and the OKin between, about 70% of the time nothing happens. Sometimes wetting my fingers seems...
Hi the is a two year g/tee on all Miele appliances. I would contact Miele and book a service call. The appliance most likely requires new clock. Modified clocks are available which allow you to change setting via control knobs rather than keypad.
Jan 16, 2011 | Miele Novotronic H350-2B Electric Single...
Need to set time on Miele Oven H398B2?
Turn the upper oven on. Hit 'MORE' once or twice until you see 'SETTINGS' touch that and navigate to 'CLOCK' Once there, you can enter the time using the keypad. Hit 'OK' to exit. You can download the manual from the Miele website or request a printed version from them.
Nov 02, 2009 | Miele H398BP2 / H398B2 Electric Double...
How to set clock and timer
reset clock, set clock on the right time by clicking + & -
Dec 30, 2007 | Miele Novotronic H350-2B Electric Single...
H348 B2
turn of at mains, wait 5 mins and turn back on then consult your handbook to set clock. i suspect you have the oven on automatic by mistake. if this don't work, you may have a problem with the clock itself. you can bypass the clock by connecting together the two contacts adjacent to the clock relay
May 17, 2007 | Miele H348 B2 Electric Double Oven
Miele Novotronic H350-2B Electric Single Oven Logo
4,014 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
