Question about Whirlpool WTW5700S
My washer won't go from one cycle to the next. stays on wash, doesn't go to rinse, etc etc. i can turn the knob to go to the next cycle, but it won't do it automatically all of a sudden.
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 15, 2011
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Kenmore model 110.24642300 will not cycle through wash cycles...will stay stuck in wash cycle until the knob is manually turned to rinse/spint/etc. Would this be a bad knob or timer or both? Thanks!
Start a cycle and remove the knob. If it still stays in agitation mode and won't advance to the spin, then you have a bad timer, or no power to the timer motor(very unlikely). If your washer goes through the cycles with the knob off then you have a bad timer knob. I have seen stripped knobs causing the timer to bind up and not advance. Good Luck Appliance Specialists
Dec 31, 2009 | Washing Machines
Cycles are off on standard top load whirlpool washer
That's probably a good idea. It's very difficult to fix stuff from this distance. Sorry we couldn't solve it, but at least we got you to the next step.
Charlie
May 12, 2009 | Whirlpool LSQ9549P Top Load Washer
Washer will not go to rinse or spin cycle
electronic problem in timer board,not being electronically moved to next stage of washing
Jan 24, 2009 | Kenmore 43142 Front Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Washer LSQ8543JQO -- in cycle issue
what brand washer? if lidswitch is bad most washers will not drain and spin to move to the next cycle
Nov 19, 2007 | Washing Machines
Open Questions:
See all Whirlpool WTW5700S Questions
Whirlpool WTW5700S Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De
