Question about SanDisk Sansa m240 MP3 Player
My sandisk sansa 1gb will not allow me to delete certain songs, i plug it in and pop up all my music but half of it isnt even visible, is there any other way to just delete everything off the device?
  • 2,574 Answers
Try this:
Note:Make sure you have a charged battery
Turn the player off
Slide the Lock switch ON to insure MSC mode
Plug it in your PC .Open "My Computer" ;Right click on the Sansa m240 icon
Click on Format Choose FAT..not FAT32
Click "Start"...OK
Unplug and let it finalize .Slide Lock switch to OFF.
That is all!
Posted on Mar 16, 2011
How do i delete music from sansa sndisk 1GB
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Good Luck, I hope this helps
Nov 18, 2009 | SanDisk Sansa e250 MP3 Player
No songs can be added
The songs that you are trying to load are probably in the wrong format. Many WMA files (used by 90% of music services) have restrictive DRM licenses that will not allow you to play certain files on an mp3 player, even though they play fine on your computer. Also, the Sansa e200 does not play songs that are in iTunes format. If you stick only to songs that are in mp3 format, you will not have such problems.
If you are CERTAIN that ALL of your songs are in mp3 format:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 18, 2009 | SanDisk Sansa e250 MP3 Player
Song titles and artists still on e250 even after delete
if you've deleted all the music then just format the mp3 player then it'll all be gone
Dec 29, 2008 | SanDisk Sansa e250 MP3 Player
Won't Delete Music
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Oct 03, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk 240 1.0 gb
I had this same problem. What I ended up doing was going into My Computer into the device itself and seeing what showed up. It appears a few new songs I popped on there the day after were appearing but nothing else. I deleted all the files, unplugged it from the computer and let the library update, old songs were still playing. Plugged it back into the machine and voila they showed up.
Aug 05, 2008 | SanDisk Sansa m240 MP3 Player
Taking music off
Your SanDisk Sansa does not allow you to delete files from within the player.
Instead I recommend that you follow the steps below to delete the music1.gif
Hope this helps
Thank You
Computerrep
Mar 30, 2008 | SanDisk Sansa e260 MP3 Player
Sansa m230 delete specific song from the player
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer1.gif..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music1.gif and delete them from there.
Either under sync panel in your windows media1.gif player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
Hope this helps
Thank You
Computerrep
Mar 26, 2008 | SanDisk Sansa m230 MP3 Player
Somehow i deleted everything!
There are a few different ways to delete songs off your player - see especially the method involving the firmware update.
Preventive Medicine: To prevent Windows Media Player from adding all of your My Documents files to the Sansa player every time you connect the Sansa to the computer - Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Set up Sync". When a window pops up, uncheck the box that says "Sync device automatically".
Quick Method 1 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Quick Method 2 - Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Slow Method, allows more control over what gets deleted: In Windows Media Player 11, the files are organized by Music, Pictures, Videos, Etc. First, you will want to plug the Sansa player into the computer. Then click the Library tab in Windows Media Player. You will most likely be in Music view. You will see two sets of folders in the left-hand side of Windows Media Player. The first set are all the files stored in your computer. The second set of folders underneath the line that says Sansa 1GB Mp3 player (I forget the exact wording) has all the files that are stored in your Sansa player. Click on the "All Songs" folder. You can individually delete all the songs that you want by left-clicking once on the song name in the middle of the Windows Media Player window, and then pressing "Delete" on your computer's keyboard. You will have to repeat this process again for images, videos, etc by clicking the little arrow next to the picture of the musical note on the upper left hand corner of Windows Media Player, and expanding the dropdown menu, and selecting "images"...then "Videos" etc.
NOTE: After plugging in your Sansa player, if you see a message that says "Connect a Device" in the Sync tab on Windows Media Player, then the cmputer is not properly recognizing your Sansa player, and you may need additional instructions from me.
-Tha Mp3 Doctor
Mar 15, 2008 | SanDisk Sansa Clip MP3 Player
Deleting from mp3
There are a few different ways to delete songs off your player.
-Tha Mp3 Doctor
Mar 12, 2008 | SanDisk Sansa c200 MP3 Player
Deleting
Plug in your sandisk into the usb driver, click on my computer you should see SANSA M230 (F:) right click on it, you should see format, click on format. And finally click on quick format, then start. That should do the trick. Note it erases all songs. Your welcome! :)
Jun 12, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
