Question about Whirlpool GS6NBEXR Side by Side Refrigerator
No ice the water works but no water in ice tray or ice light is flashing red I have no ice please help
  • 61 Answers
Icemaker not working
Here are the tests for the IDI Optics ( the red light)
Jan 28, 2016 | Whirlpool Refrigerators
Ice maker Manitowoc QD-0212A
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Jul 13, 2013 | Kitchen Appliances - Others
Red ! light comes on and will not work
If it is a steady light water tank is not properly in OR dregs counting and drip tray is full. Pull out the drip tray and wait for the red light changes in to flashing, then put back the drip tray.
Mar 18, 2010 | Saeco Odea Giro Plus Coffee Maker
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 30, 2009 | GE Profile PSW26P Stainless Steel Side by...
Not making ice flashing light in freezer door 106.53659300
There is a board for sale on eBay for $68.00.
This is a relatively easy procedure. Just have to buy the board
Mar 25, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker Not making Ice
Water is in the tray and you have freezing temps? Can you tell me a little more? The flashing red light began when the ice tray filled and did not freeze? Let me know when possible, Thanks JT
Oct 23, 2007 | Kenmore 50522 / 50524 Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
602 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
