Question about Intel Pentium 4 505 LGA775 2.66GHz 1M 533MHz CPU OEM (CPUINP463)
? mark is yellow - Intel Pentium 4 505 LGA775 2.66GHz 1M 533MHz CPU OEM (CPUINP463)
  • Intel Master
  • 27,725 Answers
If you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hopr this helps
Posted on Mar 15, 2011
Matching the sprokets pionts with the camshaft levels
Timing marks 2000 Toyota corolla (4E-FE/ 4A-FE/ 5A-FE)
Align the crankshaft pulley mark with the 0 mark of timing case.
The camshaft sprocket is at TDC when the hole in the sprocket lines up with the notch in the bearing cap
Timing marks 2000 Toyota Corolla (1ZZ-FE/ 3ZZ-FE/ 4ZZ-FE/ 2ZZ-GE)
Set the Crankshaft key in 12 'o Align yellow timing chain mark
Clock position (The key aligns on the crankshaft sprocket
with the mark on the oil pump (see arrow)
body (see arrow mark)
Align the marks on the sprockets Place the crankshaft angle plate
with the yellow links of the timing with the marks B or F, facing
chain. towards you.
Jan 18, 2014 | 2000 Toyota Corolla
Audio does't work from the motherboard?
first right click my computer then click properties then hardware then device manager scroll down to sound, audio and vedio controllers and see wether any is marked with yellow question mark or red X if its yellow question mark it means the driver is not installed properly if red X it means the device is disabled if red cross then right click the device and click enable if yellow question mark make sure you install the reight drivers after correcting this then click start setting control panel click sound and audio device then remove the tick mardk in the mute and click the volume to high and play some music
Dec 30, 2011 | Intel Computers & Internet
Multimedia audio controller have yellow question mark
The yellow question mark means there is some sort of problem. Click on the Question mark and, you should get a pop up that will give you options as to what to do next. Could be a driver.
Jun 20, 2011 | Computers & Internet
On going to the control panel, system, system properties, Hardwre then device manager; I descovered that there is a yellow question mark against DVD/CD-ROM driver. it is writen down: Optiarc DVD RW...
  • thank you my friend for your question,first step the yellow mark means that the dvd driver is missing
  • so for you to solve the problem you need to right-click at the yellow mark then select update driver
  • and thus the driver will be automatically be installed from the microsoft website.
  • and if it is installed the yellow mark will not appear again.
Dec 08, 2010 | Computers & Internet
Timing mark on crank pulley jumps abruptly about
Try plugging the vacuum advance hose itself to test the timing. Is the white Mark located where it should be? The Yellow is your advanced timing mark and should be also also be aligned with the pointer.
Dec 29, 2009 | 1988 Mazda B2200
For me problem.after installations XP atop Vista on notebook computer LG R405  has ceased work WebCam.I can't to find the driver to the web camera under XP  Help me!
The webcam on this machine is integrated.
Check your device manager and see if the item has a question mark (yellow)
1. ight click on "My Computer"
2. Click "Properties"
3. Click tab "Hardware"
4. Click "Device manager"
5. Look to see if there is a yellow question mark next to an item--you might have to click the "+" signs
If there is an item with a yellow question mark or any mark indicating something is wrong...right click and click "ininstall"
After clicking through the ok confirmations and getting out of the window..restart the computer.
Dec 24, 2009 | Computers & Internet
The yellow mark next to the Universal Bus indicates that there is some driver issue with one of the driver for your USB devices. You can try right clicking on the yellow exclamation mark, remove / uninstall the device and then click on Scan for hardware changes from Action menu. This may help in reinstalling the device.
Regarding your network card you can install in the available PCI slot regardless of the yellow exclamation mark next to universal bus.
Hope you find this solution helpful.
Please do not forget to leave feedback or ratings.
Thank you for choosing Fixya.
Dec 18, 2009 | Dell OptiPlex GX260 PC Desktop
My internal camera has turned itself off and i tried pressing crtl+alt+t whilst computer started up to get into start up, but it just turned on as usual and didnt let me go to start up to turn it on
Please try to check on the device manager if your internal camera device is disabled there or probably the driver is corrupted.
Windows XP
- click start
- click run
- click devmgmt.msc
- on the pop-up window, under imaging device, try to check if you see a red x mark or a yellow question mark. If it's a red x mark that means it's disabled, to enable it just right click it and click on enable. If it's a yellow question mark, you need to reinstall the driver of your webcam.
Windows Vista
- click pearl button (start)
- click start search box (run)
- click devmgmt.msc
hope this helps
Sep 30, 2009 | ASUS Eee PC 900 Netbook
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
The yellow mark indicates that no driver is installed properly, you need get latest mother board audio driver from manufacter site. As long as yellow mark is existing media player will not play. You don't have any problem
Apr 17, 2008 | ASUS P4S800-MX Motherboard
Intel Pentium 4 505 LGA775 2.66GHz 1M 533MHz CPU OEM (CPUINP463) Logo
41 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
