Question about Sharp Office Equipment & Supplies
I have a Sharp SF-7900 copier. After clearing a paperjam, I am getting a n H4 error. I understand that this is because it is not getting up to the proper temperature. How do I diagnose the exact cause?
  • 7 more comments
  • beararms2 Mar 15, 2011
    Should the fan be running at startup, or does it only come on when it gets warm?
    Holding down the copy button does not give an additional sub code.
    The code you gave to clear the trouble code works, but it comes right back as soon as you power it back on. I think the fuser was disconnected when I tried to clear the jam, (power was on) that is when the trouble began. How do I check the fuser assembly to see if it is ok?
    Any way to check the fuser?
  • beararms2 Mar 16, 2011
    Is there a schematic or diagram online I can look at?
    Got any instructions on how to do that?
  • beararms2 Mar 17, 2011
    Does the entire fuser assembly need to be replaced, or one of it's components?
    I have already pulled the fuser assembly out and cleaned it, however it is not getting hot or even warm like it should. ???
  • beararms2 Mar 18, 2011
    I assume trying to pull the fuser assembly out with the power on most likely created the problem. Which of the three items you mentioned would have been most likely damaged by this action? Would all three keep it from getting up to temp? As I mentioned, the fuser rollers are no longer getting warm or hot to the touch with the power on.
    Genius:
  • 1,622 Answers
to solve this problem perform the following procedure:-
It is not H A It is h4.It is power error code.When your copier heater lamp is not on then show it.
This error indicates a problem with the fuser on the machine. You will need to replace the fuser unit and reset the code. The fuser is fairly simple to get out, you will need to remove the back cover and the jam access door on the right side of the machine. At that point, the fuser is simply held in with three screws and a connector.
To reset the code you have to go into service mode by pressing this sequence of keys ("C" -> "Exposure" -> "C" -> "Exposure"). You will need to press them fairly quickly, about a second between each press, and confidently. You will know you are in service mode because the display will change to "--" and flash. At this point, enter "14" as though you were making 14 copies, and press the green start button, then press the "CA" key to exit service mode. The machine will begin restarting itself and if the problem is resolved it will come to ready.
These machines were notorious for giving H4 errors randomly and without a real reason, so I would suggest that you try resetting the code one time before calling it in for service. If the code comes back after you reset it once, or comes back on a fairly regular basis (meaning more often than once a month), I highly recommend calling a professional repair technician in for service.
Thank you for using fixya
Posted on Mar 18, 2011
    Genius:
  • 1,043 Answers
Normally to clear the H4 error we replaced the fuser lamp, and you would also need to check the thermistor and rectifier. That was a few years ago though, and I mention this as I know it was already becoming difficult to find parts for the copier. I do not have the service manual for this copier anymore, but if you do, you will see that the thermistor and rectifier are part of the fuser control board.
  • 10,515 Answers
The H and 4 error is a Fuser related issue.The fuser is the heated roller than seals the toner onto the paper.Unfortunately, the the only way to check it by looking at it visually or putting your hands close it by.However, be advised you might hurt yourself you are not experienced enough to work on these printers. However, as a matter of fact H4 is more often related with the Fuser.As resetting doesn't help the cause, as it came back, replacement is the only option left.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 17, 2011
  • taran_2005
    taran_2005 Mar 17, 2011
    Thanks for your response!!
    For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
    You don't have to replace the assembly. The Fuser has to be replaced.
    I wouldn't recommend doing it yourself.If you want to do it yourself:
    To remove the fuser, complete the following steps.
    Turn off the device, and then disconnect the power cable.
    Rotate the locks on the fuser to the unlocked position.
    1: Rotate the locks
    Grasp the fuser handle and pull the fuser assembly from the device.
    2: Pull the Fuser assembly
    The parts on the internal surface of the fuser are very hot. To avoid from heat, do not touch those parts.
    Using
    both hands, slowly and steadily remove any print media from inside the
    device. Then, carefully reinsert the fuser and secure the locks.
    Reconnect the power cable, and then turn on the device.
    Hope i helped you.
    President:
  • 1,216 Answers
Just replace this component to make everything working again.
Posted on Mar 16, 2011
  • Aviral Saxena
    Aviral Saxena Mar 16, 2011
    There are only 3 causes to it.
    Heater lamp open
    Defective installation
    of thermistor
    Thermostat
    open
  • Aviral Saxena
    i'm sure there is not try replacing the heater lamp.
  • 17,970 Answers
The cooling fan goes bad and generates false signals. Replace the fan if everything else checks good. It may also cause intermittent power failures "machine goes dead".
Either the fuser did not heat up in time. If you hold down the copy button it will give you a 2 digit sub code (01, 02, etc). Check your lamp to see if they are coming on.
Hope helps, good luck.
Posted on Mar 15, 2011
  • 1 more comment
  • ZJ Limited
    ZJ Limited Mar 15, 2011
    On SF-7800, H4 causing of power interrupting or high voltage
    It is a fuser temperature error or one of the sensors is dirty. You
    could try removing the fuser assembly - ensure power is switched off-
    then try cleaning the sensors as they tend to get paper dust and melted
    toner which collects between the surface which senses the heat from the
    fuser `Hot` roller. if this does`nt fix it you may need to replace the
    fuser. There is also an engineer code that you can enter to clear the
    fault so if you know of a friendly sharp copier engineer.
    Try this reset procedure... to remove this error
    press "C" "interrupt key" "0" "interrupt key" The machine goes
    off then press number 14, switch off machine then switch on.
  • ZJ Limited
    It isn't fixing part, the fuser assembly is the part that uses pressure and heat to melt the
    toner to the actual paper. It consist of gears, bushings, heat rollers,
    pressure roller, paper pick fingers and other components, If you business class Ricoh, Sharp, Canon,
    Gestetner, Savin and other copier printer scanners then the fuser
    assembly is rebuilt then majority of the time. Other cases, if you have
    an HP laser printer, Lexmark printer then for the most part you change
    the entire fuser assembly. Check in this link for parts replacement: sharp/parts/fusers_sharp.
  • ZJ Limited
    ZJ Limited Mar 17, 2011
    Tehm its possible that entire fuser assembly need to be replaced.
Error for sharp SF 2540 H4
H4 means; Heat roller low temperature detection. This is an error in your fuser and you will likely need to get a service technician to take a look at your copier.
Sep 15, 2010 | Toshiba e-Studio65 Copier
I own a sharp SF-7900. My pages are coming out black
I'm sure you may find a manual, but your copier is rather old.... When you make a copy do you get a error code? How about when you make a copy, do you see the scanning lamp turn ON? Here is you thing you can try, make sure the Primary Corona unit is pushed in all the way in. It has a grey handel on it and it should be found right above the Drum... Good Luck
Apr 19, 2009 | Sharp Office Equipment & Supplies
How do I Clear H-04 code?
C INTERRUPT 0 INTERRUPT
14
START
Apr 06, 2009 | Sharp SF 2040 Copier
H4 error on Sharp SF 7370
The heater lamp isn't coming on either because of blown heater lamp or thermostat reset itself . Clean the thermistor and replace any of the above defective part.Then press C, 0, 0, C and press 14 press READY.
Mar 12, 2009 | Sharp Office Equipment & Supplies
Code H4 is showing on the machine
h4 code in sharp .that s fuser temperature very high .just reset it.press clear key,auto photo key,clear,auto photo key.copier goes dead .when it goes dead just press 14 then start key.copier will bi ready after some time.it works.by mian jee
Dec 17, 2008 | Sharp SF 2020 Copier
MY SHARP AR5316 DISPLAY H4 WHEN I PUT IT ON
Here is the process
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Dec 11, 2007 | Sharp AR-5316 Advanced Digital Imager...
85 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
