Question about Garden
Stihl pole saw ht131 will not retract fully.too stiff to close the last 20"
5 Suggested Answers
  • 22 Answers
SOURCE: looking for a manual for a stihl pole power saw
Your local Stihl dealer can order the manual for you. It might be free or there could be a small charge for shipping. Either way, it's worth having the manual and Stihl WANTS you to have the manual. Be sure to have your model number and serial number with you when you go to the dealer.
Posted on Jun 16, 2009
  • 4088 Answers
SOURCE: I have a Stihl ht101 pole saw that is not oiling
Remove the bar and chain and run the saw. Does oil come out of the side port? If not, check the pump, lines, and in-tank filter. If ok, clean all the holes in the drive end of the bar including the small holes that pass oil to the chain slot. Compressed air helps here. Clean the chain slot. Oil the chain manually after assembly.
Posted on Sep 12, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan PP446T Pole Saw. Will run only if choke is
It is running lean. There is an air leak somewhere allowing to much air into the cylinder or crankcase. Continuing to operate lean may cause failure. If fuel delivery lines have no pin holes or cracks probably time for some professional help (pressure tests). Remove clean and reinstall the muffler (carbon fouling can also cause this). If the saw cannot exhale, it cannot inhale. HTH
Lou
Posted on Jan 23, 2010
snowghost1
  • 784 Answers
SOURCE: I have a Stihl .029
I have owned and use Stihl saws for the past 18 years and I have seen both these problems many times. as for the chain 'getting tight' -- when you go to adjust the chain, make sure you are lifting up on the tip of the bar as you set the tightness -- you should be able to only pull the chain away from the bar about 1/8th of a inch. now, while tightening the bar bolts make sure you still are pulling up on the tip of the bar,, and make sure the bar bolts are nice and tight -- not to tight though, the bolts that Stihl uses are a very weak point on their saws and I have broke more than just one. but make sure after one is tight that you tighten the other one and then give the first nut one more 'little' nudge tighter. new chains do have a break in period and they have been known to tighten up and loosen as they are running,, just keep your eye on it for awhile and thighten or loosen as needed.
now I am kinda confused on your next problem -- you say ' winter mix bar oil ' -- using this oil should not have anything to do with it stalling out, ( enless you are mixing bar oil with your gas ?? ),, make sure you are using Stihl 2-stroke oil to mix with your gas at a ratio of 50:1,, ( you can buy small bottles that mix with 1 gallon or a bottle that will mix with 5 gallons -- use 'em ). one thing that I have had troubles with when my saw wants to stall out is the fuel filter inside the fuel tank in the wrong position and is sucking air. also I have had fuel lines that crack and/or split and they **** air.
now the winter bar oil -- please,, I have been running Stihl saws in temperatures ranging from minus -5 to 100 degrees above and I have always used the SAME bar oil year round and had NO problems. on the side of the saw there is a bar oil delivery speed screw and you can adjust it to flow more or less -- your manual should show you the exact location of this screw,, make sure you clean out any debris that might be blocking the weep hole for the oil delivery. you need to make this adjustment with the bar and chain off the saw and you will see the flow of the oil and you can adjust to a good flow.
I am a firm believer in buying and using Sthil chainsaws,, I will never buy anything else,, they are great and out last any other saw I have used or seen,, and your Farm Boss is a great saw and should give you many years of trouble free use.
one suggestion that I would make real quick is to ' change your saw mechanic ' -- find one that has been ' WORKING ' on chainsaws ( not just selling them ) for along time,, someone that has your interest at heart and is there to help you,, not just to take your money.
(((( I am still laughing at the ' Stihl Winter Mix bar oil :-) )))).
good luck with your saw,, and if you have anymore questions about this please feel free to write me back here and I will do my best to walk you through what it is that you need to know and do. again - I have been using and working on chainsaws for most of my life.
have a great night,
c...
Posted on Feb 10, 2011
How do you get the drive shaft out of the pole on a stihl 101 pole saw?
Bought brand new! I saved up for this product for awhile since they are pretty pricey. I also own acreage in the Midwest so this tool is much needed. I owe 2 older stihl chainsaws and fs70 trimmer. I work sometimes 70-80 hours a week so anytime I have on the weekends to clean up tree damage from storms, etc is precious.
More details about the best pole saw go to the link The Best Pole Saw In 2018 Practical Overview of Top Pole Saws
May 31, 2017 | Stihl Garden
The unit was not as advertised. Hard to start, runs poorly and won't idle. Had to take it to the local stihl dealership for service.
For best pole saw open the link The Best Pole Saw In 2018 Practical Overview of Top Pole Saws
Mar 20, 2017 | Stihl Garden
STIHL pole saw 101
Hi Little Bird
Chances are that the clutch needs servicing or replacement.
Here's a link that explains:
http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm
Cheers
Jun 06, 2016 | Stihl HT101 Pole pruner
Stihl ht131 shaft spacers came out when shaft came apart
Here is the parts manual.. it shows exactly how to rebuild the shaft and spacers.
Feb 26, 2014 | Stihl HT131
HT131 POLE SAW MANUAL
I'll send you a link to the full 'illustrated parts manual' maintenance wise, i regularly oil up the inner shafts and brarings in the tube, also grease up the shaft that has the plastic sleve over it, Because it can become dry and start to grip within the case and vibrate.
Jul 29, 2013 | Stihl HT131
Stihl HT75 pole saw
Stihl HT 75 pole saw is great. If you want easy to pruning tree by the best pole saw go to the link The Ultimate Remington Electric Chainsaw Reviews
Jan 18, 2012 | Garden
Clearance for stihl ms 250 ignition coil
Rotate the flywheel until the magnets are under the module, insert a thin business card into the pole gaps, loosen the module screws and allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the pole gaps don't close further. Hope this helps!
Dec 28, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
