Question about Gateway Desktop / Intel Pentium Processor / 6GB Memory / 1TB Hard Drive (SX280325E)
I need a new graphics card with an HDMI output, preferably 1gb, for the Gateway SX2803-25e computer recently purchased.The one furnished with the computer will not support many online games. Can you recommend any that may simply plug in and go? The prices have been falling dramatically on older video cards recently.
    Sergeant:
  • 186 Answers
You have a PCI Expres x 16 expansion slot so can can pretty much put any video card into it. But don't know how much space you have in the case , you might need low profile one. Or just how much money you want to spend. Here is an example of a 1GB low profile card that have HDMI out. EVGA 01G-P3-1302-LR GeForce 8400 GS Video Card - 1024MB DDR2, PCI Express, DVI, VGA, HDMI, Low Profile
You can do a search on this card.
Posted on Mar 15, 2011
Testimonial: "Fast reply, and answered unanswered questions not contained in the original. Didn't think about the profile aspect! Good stuff, guys!"
    Scholar:
  • 172 Answers
You can buy Intel Graphics Media Accelerator X4500HD5 ..
Please rate & vote , if you solution....
Thanks
Sandeep
Having problem setting up hdmi on my gateway e1 tower
if you have a DVI port on your PC a DVi-HDMI converter is fairly cheap
DVI is one of the most common graphics card output formats for any PC. a VGA-HDMI adaptation is possible but usually very difficult
Feb 19, 2014 | Gateway Computers & Internet
Gateway dx4300
One of two possibilities; the Motherboard or power supply. In my case it was the Motherboard. Those cheap capacitors tend to go bad over time without being used. I purchased a replacement motherboard(Foxconn RS 780 "bengal") from a place in WI. Skyline on Ebay. I would do a search on Ebay for Gateway Foxconn Bengal RS780 Motherboard. Then get the number and call. You can use the old processor, ram, and maybe the graphics card, but I'd run the onboard graphics first(if you do happen to have replaced the motherboard) to make sure the graphics card isn't causing an issue. You will need to do some research and reading on the net about installing new motherboards and hardware. If the motherboard is the same, Windows should still work with it. Do your homework first as this is only a suggestion as to your problem. It is what happened to my Gateway DX4300-03. Check all power supply related, graphics card and wire connections first before you consider the motherboard thing.
Oct 12, 2012 | Gateway DX4300 Acer Foxconn Bengal RS780...
How To Use My Olevia Television As A Computer Monitor
There are a number of ways this can be done. It will depend a lot on the graphics card you are using in your computer. All graphics cards released for the last few generations from both ATI and Nvidia (and all Intel IGPs labeled HD) have an HDMI output. This is the simplest option. You simple connect the TV via HDMI, set it to the right output, and power up the computer.
If you do not wish to use the speakers in the TV, then you can manually set the audio output to default to your other speakers.
If your graphics card/computer does not have an HDMI output, you will need to buy an adapter for one of the other outputs. DVI to HDMI would be the best second options. Then S-Video (which should look like a circle with dots a a line in it) to component (5 inputs, 3 video/2audio). The adapter will only have plugs for the video.
Any connections beyond this should be avoided as they will not be able to match the resolution of the TV. Forcing the TV or graphics card to upscale say a VGA connection to the proper resolution will create a lot of distortion and give you a terrible image.
Apr 27, 2011 | Olevia LT42HVi 42 in. LCD Television
I have a panasonic Viera and I'd like to play my computer through it. The computer picture works fine through a converter to the HDMI cable input but how do I get sound? I need a separate cable from the...
does your computer graphics card have a hdmi output on it? i had a same problem the coverter input will not let sound though it u would need a hdmi output from the computer or need to connect a separated sound output as the form of speakers from the computer itself, i mite be a problems with drives, try updating the graphics card drives. this mite solve the problem as well. hope this helps
Aug 13, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
What type of graphic card i can buy for my gateway 556 ge computer
First increase the ram from 512 Mb to 1Gb then purchase the 256/512 mb Graphics Card in market.
thank u sir .... Have a nice day
Apr 17, 2010 | Gateway 556GE Intel Pentium 4 630 3GHz(HT)...
Suggestions for new graphics card on Gateway 300s
just check what motherboard version your computer is running on and just advise the supplier to supply you with a graphics card that well fits for that motherboard.....
Oct 11, 2009 | Gateway (6000736) (4 MB) Graphic Card
Problems with audio after installing radeon hd 2400
This happens because the video card has hdmi output. Since hdmi output can carry audio signals also, the audio driver gets disabled. Uninstall audio driver and video driver both, install the video driver, and then install audio driver. after installing the audio driver, in playback and recording devices choose choose the audio output device you purchased along with the computer. This should fix the issue.
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 12, 2009 | Diamond Multimedia Stealth RADEON 9250,...
Choosing a GPU
SAPPHIRE 100256L Radeon HD 4670 1GB
  • Chipset Manufacturer: ATI
  • Core clock: 750MHz
  • Stream Processors: 320 Stream Processing Units
  • Memory Clock: 2000MHz
  • DirectX: DirectX 10.1
  • OpenGL: OpenGL 2.0
  • HDMI: 1 via Adapter
  • DVI: 2
Although it only has a 128bit memory interface it makes up for this by the large amount of stream processors and the high core clock. It's cheaper than the 9600 and better.
Nov 02, 2008 | Computers & Internet
Choosing Graphics card.
NVidia Geforce series, i have found is the most reliable and less likely to screw with your system in a negative way like Radeon.
I have used all forms of video cards in the past. the GeForce series is stable. I have a Dual HDMI output card myself, its only a 512mb DDR2 but it does the work load of MMORPG's with ease and my system very rarely has issues unless i am trying to run more than i rightly should. So my suggestion is the GF9600T. It is powerful beyond beleif and will make resolution and texture ratio through the roof.
Thats my professional opinion on this.
Gateway Desktop / Intel Pentium Processor / 6GB Memory / 1TB Hard Drive (SX280325E) Logo
375 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
