Question about Neff Ovens
Neff u1722 tripping rcd after 30min use of bottom oven steam accumulates on top oven/grill
3 Suggested Answers
  • 44 Answers
SOURCE: Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Posted on Mar 19, 2009
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Posted on Nov 02, 2009
Neff U1422 bottom element faulty, is it needed?
the only problem might be hat the oven will not come up to proper temp with out that element .
Oct 16, 2015 | Neff Ovens
Neff double oven trips rcd when either oven is turned on
your heater elerment has gone in the main oven i had the same problem if you need help takeing it out and see if its the problem get back to me ok
Nov 03, 2012 | Neff U1421 Double circotherm Electric Oven
U1442 main oven not heating
If you are sure there is 220v going to unit, it most likely is element or click / control. If you have a ohms meter, you can test the element
Sep 07, 2017 | Neff U1721 Double circotherm Electric Oven
Oven not producing any heat
just the oven? then more than likely the element. if the stove eyes are not working as well, then your looking more at a sensor, thermostat, fuse, breaker, etc. almost always an element though
Mar 20, 2012 | Electrolux Ovens
Rcd trips after 1 minute of using top oven or grill
It could be the top oven overheat thermostat going faulty. With something like this the only way to find it is to take the oven to bits and use a test meter to see what is causing the problem. Just to let you know, on the 720, the grill works independent of the timer/clock. So if both the top oven and grill are generating the problem, that is where I would start to look.
Dec 13, 2011 | Stoves 720EF Electric Double Oven
Keeps tripping out rcd 63 amps when warming up after about 10 minutes
If your oven is rated above 14kw then change the RCD to 80A. But if its rated less than this then please check shorted element and change them
Jun 18, 2010 | Neff U1721 Double circotherm Electric Oven
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Hi
regards dan
Mar 19, 2009 | Neff U1452 Double circotherm plus Electric...
Ovens Logo
41 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
