How do I change ink cartridges on Canon Pixma MX700?
    Scholar:
  • 172 Answers
1 Turn on the Canon MX700 printer by pressing and holding down the "Power" button. Open the paper output tray by pulling up on the tray. An arm will unfold from inside the printer and hold the tray open.
2 Apply pressure on the ink cartridge tab and remove the ink cartridge. A flashing light on the outside of the ink tray will indicate what cartridge needs to be replaced.
3 Remove the film, orange tape and protective cap from the replacement cartridge. You can throw away any trash. Do not touch the metal contacts on the new cartridge; this may cause the cartridge not to work.
4 Insert the front end of the replacement cartridge into the ink holder. Make sure you are placing the correct color in the correct spot. There is a sticker on the outside of the holder indicating what color goes where.
5 Apply pressure on the cartridge where it says "Push" until the cartridge snaps into place. The once flashing light should turn a solid red indicating the cartridge was replaced correctly.
6 Close the paper output tray. The Canon MX700 will start cleaning the printer heads. You cannot print during this time. The entire process may take a minute or two.
Please rate & vote , if you like soution..
Thanks
Posted on Mar 15, 2011
    Problem Solver:
  • 5 Answers
I can walk you through, step by step, but I would simply be copy and pasting the solution.
Check out pages 85-88 of this pdf (pages are numbered 81-84)
This url has all the information you need, including on screen manuals and PDF's of the original manuals.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx700#BrochuresAndManuals
  • 99 Answers
With the printer on, first open the paper output tray, then lift up on the front of the control panel and it will tilt back. The cartridges should move to the removal position. Then just push the retainer clips for each cartridge you need to replace.
    Sergeant:
    Champion:
  • 239 Answers
    President:
  • 1,335 Answers
With the printer power on, raise the printer clamshell to expose the printer ink cartridge carrier. Wait for the carrier to come to center rest. Remove the flashing cartridge and replace it with a suitable replacement (OEM or Refill/jAftermarket). Close the clamshell lid. You should be back in business. Make sure to recycle the old cartridge (you can get a free recycle envelope from the Post Office). Let me know if you have any more questions. Thanks.
4 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Canon mx700 rejecting remanufactured ink cartridges
big issue with remanufacturing is how integritous is the fit of the cartridge, and also the interface. When these are re cut, so to speak, tolerances can stack up, and one thing about Canon, is they are a stickler for tolerances. You may have an issue with the cartridge fitting in the carriage, but not interfacing with the system. Happens sometimes..
got backup?
Posted on Feb 15, 2008
Vista94
  • 5 Answers
SOURCE: How to change the ink cartridge?
1: Turn printer on
2: Lift up front panal (below scanner)
3: Wait for print head to appear
4: Remove old cartridge (push down & towards you)
5: Push new cartridge into position
6: Close panal & wait for the Printer to prime the cartridge.
If you are using a PC with check it works in the printer section of Control Panal
Posted on Mar 31, 2008
How to refill pixma mx700 magenta ink tank without
The colors are individual. That machine takes the Canon CLI-8. I would suggest reading your manual on what the procedure is for changing the ink cartridges out, it typically varies slightly by machine. There should be an option somewhere one of the menus to change the ink cartridges. When you buy a replacement be sure you buy from someone who isn't trying to scam you. I would recommend Cartridge World, of course, or OEM. Do not use cheap online cartridges, you will only have headache later.
Feb 15, 2010 | Canon PIXMA MX700 All-In-One InkJet...
My Printer is saying, some ink tanks are not
If the cartridges are in the correct position, you may have defective cartridges. If you are using after market cartridges, the electronic sensor chip built into the cartridge may be defective. I would remove the cartridges and try using OEM cartridges. You can also try new aftermarket cartridges from a different vendor. This should clear the problem.
Let me know if this does not solve the problem and we can look into other potential solutions.
Nov 01, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Wont print black
Change the black ink cartridge.
Jun 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Ink Cartridge
how do you set the ink tank on a mx700
Feb 25, 2009 | Canon MX700 Office All-In-One InkJet...
My ink lamp does not light red-pixma mx700
Have you installed the print head? It's a separate item in a foil colored sealed package. It must be installed and locked in before inserting the ink tanks. If you have done this and still get no lights on the ink tanks, there is something wrong with the unit itself.
Nov 05, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Will PGI-5BK and BCI-3E ink tanks fit in the MX700?
Ink Tanks:
PGI-5BK, CLI-8C/CLI-8M/CLI-8Y
According to the canon australia website these are the inks for the MX700
Feb 20, 2008 | Canon MX700 Office All-In-One InkJet...
got backup?
Feb 15, 2008 | Canon PIXMA MX700 All-In-One InkJet...
177 people viewed this question
k24674
