Question about Akai PT46DL10 46" HDTV-Ready Television
FLASHING GREEN LIGHT CONTINUOS, NO PICTURE OR SOUND
I HAVE A 46" AKAI DLP PROJECTION TV. MODEL NUMBER # PT46DL10 MFG DATE: JULY 2005. I HAVENT A CLUE TO WHAT TRIGGERED THIS, BUT WHEN I PRESS THE POWER BUTTON IT SOUNDS LIKE ITS ABOUT TO COME ON, YOU HEAR THE FAN AND I GUESS THE CAPACITOR POWER UP, BUT THEN THE GREEN BUTTON IN FRONT CONTINUES TO FALSH GREEN ON AND OFF, THERE IS NO PICTURE, NOT EVEN THE WORKS NO SIGNAL. IS IT AN INTERNAL POWER SUPPLY PROBLEM, BUT I WOULDNT GUESS THAT BECAUSE IT GETS POWER TO THE TV, HOW COULD I DO A CHECK FOR THIS, OR IS IT SOMETHING ELSE..
THANKS
CHAD COSGROVE
EMAIL: CGROBE21@YAHOO.COM
PHONE: 504-606-7934
  • CGROBE21 Aug 03, 2008
    MY MAN, YOU SOLVED THE PROBLEM, I THOUGHT IT WOULD MORE COMPLICATED THAN THAT, APPRECIATE THE INFO. BEST OF LUCK ON YOUR APPRENTICESHIP
    THANKS,
    CHAD "DJ C-GROVE" COSGROVE
    MYSPACE.COM/CGROVE504
Check your lamp and see if it is either broken or the filament is black on any part
Posted on Aug 01, 2008
A red power, a green timer, and a red lamp led lights are flashing on t front power panel.
Likely an AKAI DLP made actually by Samsung. All 3 lights blinking is lamp failure. You can fix yourself with owner's manual.
Sep 29, 2014 | Akai PT46DL10 46" HDTV-Ready Television
My akai dlp tv stopped working
Akai is really Samsung---
Remove and inspect lamp to see if shattered inside--it is a cartridge and very easy to remove.
With it out look where the lamp faces and see if the color wheel pictured here is intact (no pieces missing etc).
Apr 16, 2012 | Akai PT46DL10 46" HDTV-Ready Television
Green light flashing and no picture on our tv
2004-Model H 347 - 10839 Phillips big screen HDTV. The picture went 3-D.
Dec 25, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Akai, PT46DL10 Has sound, no picture
make sure all componet cables are in the right color coded spots on the back or side of the tv and you are on the right componet if using a cable box make sure using componet / monster cables not all cable companies support hdmi if that is how you are trying to hook up make sure to check with them
May 14, 2009 | Akai PT46DL10 46" HDTV-Ready Television
I need a remote for model # pt46dl10 akai tv lcd 46 in
have same tv searched and tryed alot of universal ones that where supposed to work but did not finnaly found out only logitec harmony 550 universal remote works bought on on craigslist for 65 candian and works perfect with this model
May 05, 2009 | Akai PT46DL10 46" HDTV-Ready Television
AKAI Rear Projection 46"TV has a blank picture with sound only
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Thomas
Jan 19, 2009 | Akai LCT2715 27 in. LCD Television
My akai dlp tv is flashing power and lamp the red lights then to the timer is also flashing green light
the back cover is not on the TV correctly. on the back cover there is a safety switch so that the lamp light is not exposed. The lamp emits radiation and UV rays. Not healthy.
Dec 23, 2008 | Akai PT46DL10 46" HDTV-Ready Television
No picture Akai PTDLP46
It may be the ballast , I've the same problem in here in quebec, and i don't know where i can buy it. the part number is P306-0022. Normal Cost is $199.99
Apr 18, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Need new Jl amp
DLP LAMP SOURCE. PO BOX 503882 SAN DIEGO CA.92150
Mar 12, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Akai PT46DL10 46" HDTV-Ready Television Logo
367 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
