Question about Kohler Wellworth Elongated Peacekeeper Toilet by - Seat Actuated Flush
Peacekeeper toilet seat flusher quit working. One of the wires from batteries to the 'black box' that does the flush broke off too short for me to re-solder it. Replacement is $400. grrrr. Any way to transform the tank into a standard flush? No holes in tank for the flush handle. All else inside the tank is identical to a non-peacekeeper.
    Brigadier General:
  • 4,736 Answers
How about adding a section of the same gauge wire and soldier the connections together. Be sure you use Heat Shrink Tubing to cover the splices.
Hope this helps solve your problem.
Posted on Mar 15, 2011
We replaced the flushing mechanism with a new exact duplicate. Now it wont stop running. How do I adjust the flusher? and how do I get more water in the toilet bowl?
The fill valve is adjustable for water level. You should have extended it to match the original height. running water check flapper valve to ensure is is seated, the the chain may be to short and not letting is fully close. If there is excess chain it can get under flapper. Look on YouTube for videos.
May 18, 2018 | Home
Toilet won't flush...seems like no power
hi i have a thetford casset toilet but my flusher is not working i have cheked fuses but i am stumped now please help
Oct 18, 2011 | Thetford Porta Potti
I have a Kohler 81100 pressure flusher that came with the house when I bought it. Can I remove the pressure system out of the toilet tank and replace it with a regular flushing system?
As a general rule, no However contact Kohler, they may give you a discount on a replacement toilet, as there have been some recall issues.
Jun 05, 2011 | Home
My toilet is a duravit 1930 series model with Euro style push flusher rather than handle. Internal flushing mechanism is not traditional float ball. toilet water constantly leaks from tank into bowl...
A fairly easy ( but messy ) fix - get a replacement tank to bowl gasket and bolt kit, shut off water supply, drain tank, remove bolts ( you might have to cut, depending on your water source and minerals in your water). Remove old gasket and clean surface with 00 grade steel wool. Replace gasket, install new bolts, remount tank.
Good luck!!
Nov 17, 2010 | Duravit Tribeca US-Type Elongated Toilet...
We bought the Jacuzzi Perfecta toilet 1 year ago
The complication here is that Jacuzzi does not make toilets anymore than Sears makes refrigerators. In Sear's case their Kenmore refrigerators are from Whirlpool with the Kenmore name.
It is my understanding that Eljer was the manufacturer of the toilets with the Jacuzzi name typically sold at box stores. With that as a starting point, surf the web for any Eljer toilet tank replacement parts and see if you can find a similiar flusher
Jun 01, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Not flushing
take the lid off the tank and make sure that the chain is still conected from the flusher handle at the top of the tank to the plug at the bottom of the tank
Dec 09, 2009 | American Standard 2002.014 - Champion4...
The automatic flush mechanism isn't working
You need a rebuilt kit from kohler 1-800-4-kohler is the number to call
Oct 05, 2009 | Kohler K-3423-XU Wellworth Round-Front...
Toilet keeps running even when manually lifting floater to max
check handle to ensure no tension is on the flapper chain when not being flushed. check flapper to ensure positive seal to flush valve. check water level to ensure not overflowing into flow valve. if that's the case, lower water height.
then if still doesn't work, change flapper,
all else fails, change flush valve.
good luck,
steve
Oct 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler Wellworth Elongated Peacekeeper Toilet by  - Seat Actuated Flush Logo
79 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
