Question about HP Office Equipment & Supplies
HP Photosmart C3180 All in one won't print. Put in new color and new black cartridge. Tried to print some black text and what came out was blue boxes & lines and pink & yellow color.
  • 1,179 Answers
Hello there
Might I suggest downloading and installing the latest drivers for your HP Printer.
damnor01
Posted on Mar 15, 2011
  • 2 more comments
  • damnor01
    damnor01 Mar 15, 2011
    See my published guide entitled
    How to Install the latest drivers for Hewlett Packard Printer!!!
    Copy this link into your browser:http://www.fixya.com/support/r8587707-in...
    That may get it going again!
    Thanking you
    damnor01
  • damnor01
    Use the software for your printer and clean the Ink heads, this will get the ink to flow through the system! Also try removing the power and USB Connection for 2minutes and then reconnecting the Printer to the computer and power on. Try different USB ports on your computer!
    Tell me how it goes!
    damnor01
  • damnor01
    Print a Test page. Navigate to the Windows control panel and double click printers and faxes. Right click on your printer and select Properties. Click the button to print test page found on the bottom right of the box.
    damnor01
  • damnor01
    damnor01 Mar 17, 2011
    See my published guide entitled How to Install the latest drivers for Hewlett Packard Printer!!!
    You could also try using the software that came with your printer, you would want to align the printer head as well as cleaning the head/nozzles.
    Also navigate to the Windows Control Panel and double click Printers and Faxes. Then right click on your printer and select properties. Now click the button to print a test page.
    Says Print Test Page.
    Are your ink cartridges original HP ink cartridges for your exact model of printer? As this problem is common with generic inks as the microchip within them does not work well.
    Tell me how it goes.
    Thanking you
    damnor01
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
I have an HP Photosmart C3180 printer color ink issue. Instead of printing yellow its printing pink. I've cleaned the head multiple times and the ink cartridge is brand new. Please advise. Thanks!
If what you're saying is still the result after cleaning everything up, there must already be something wrong with the printhead because the printheads are the one's that are responsible for the mixture of the ink cartridges.
Try calling HP Tech Support. They might still be able to replace the printheads for you.
Feb 03, 2011 | Office Equipment & Supplies
Region codes for France for a photosmart c3180 all in one
Well I had the exact same problem with a C3180 bought in the USA and I moved to France. I called the HP tech support and after I bought 5 brand new cartridges upon their recommendation we haven't been able to print the 10 tap test page
I recommend that you try doing that before you call them otherwise you will be wasting your time
To print the 10 tap test page you need to press simultaneously CANCEL and START COLOR COPY. I couldn't print the 10 tap test page because the printer will not recognize the cartridges bought in France (START COLOR COPY and START BLACK COPY blinking + E in front of COPIES)
If somebody knows an alternate method to print the 10 tap test page, please share it as this is the blocking point with HP support
Thanks
Feb 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
HP C3180 prints only black and white. The black and color cartridges have ink.
do one thing...take out the cartridge then clean the coper contacts..and then reinstall them then try to print it will work
Jan 18, 2010 | HP Photosmart C3180 All-In-One InkJet...
Printing with one Cartridge?
ufortunatley you will have to have both cartridges in the printer for it to function there is no way for you to disable the chartridge check that the printer doe's on power up
Regards
Al
May 25, 2009 | HP Photosmart C3180 All-In-One InkJet...
Hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
May 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Ink cartridge
Black HP 92
Color HP 93
Photo HP 99
Jan 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
mukhtar21 shaikh
mukhtar21 shaikh
