Question about Home
Can you tell me what a spread is on a faucet?
The spread is the distance between the hot and cold water pipes coming out of the wall. This can vary between fausets.
Posted on Mar 15, 2011
Do you have a handle set with a 7 inch spread instead of a 8 3/4 spread and model #
Yes we do. how many would you like?
  • Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount ... www.amazon.ca/Kingston-Brass-CC543T8-Vintage-7-Inch/dp/B0026ZPI0Y
    • KINGSTON BRASS
    Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount Leg Tub Filler with Hand Shower, Satin Nickel in Showerheads & Handheld Showers.
  • Kingston Brass KB967 Magellan II Widespread Lavatory ... www.amazon.com > ... > Rough Plumbing > Faucet Parts > Faucet Handles Kingston Brass KB967 Magellan II Widespread Lavatory Faucet 8-Inch to 16-Inch Centers 7-Inch Spout Reach, Satin Nickel and Polished Chrome
  • images of 7 inch spread faucet bing.com/images th?id=oip.m9aaf750d3da8ce6a24cbe32ef9078ae8o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m643aef6e35c24789db3419b21dd47a91o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.ma09426c72dcc25d64ff92045ab194af1o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9b0dc70d9ab53ad1ecca18fd130db74bo0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9afd6495c16d35699054f30b9ee4d7e7o0&w=104&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of 7 inch spread faucet
  • Water Creation F6-0007-05 Vintage Classic 7-inch Spread ... www.overstock.com > ... > Bathroom Faucets > Water Creation
    • 5/5
    • 1 RATING
    • $409.17
    Shop for Water Creation F6-0007-05 Vintage Classic 7-inch Spread Deck Mount Tub Faucet with 2-inch Risers and Handheld Shower. Get free shipping at Overstock.com ...
  • Apr 16, 2016 | Plumbing
    How to mount pfister brea( pump)model to spread out 3 hole counter
    i do not think you will ever find a cover plate to do the job . but you could put a soap dispenser in one or possibly a filtered water tap in .
    Feb 23, 2015 | Plumbing
    I have a ten year old American Standard Reliant pullout kitchen faucet. It leaks from the body into the cabinet below the deck. I removed the cartridge but was unable to remove the internal body. The...
    Hi, Ok I see your problem? LOL The feed lines for the faucet are too close together at the min. you must spread the lines ever so slightly not to over bend, just enough to get the head/bottom of the hose to pull up thru the top. Fun job: level 6 on a scale 1-10. Have at it !
    Sep 06, 2013 | American Standard 4205.001.021 Reliant+...
    I replaced the plastic stem on a 8 in wide spread faucet and the hot water side starts running on its on after sitting a few hours and won't turn off
    take the handle off and spin the cartridge 180 degrees there are little ears on the sleeve just pry it out and turn so the ares snap back in place but just turn it if it does not work turning it clockwise then take it out again and try it the other way its a trail and error thing you must turn the water off first or you will get awful wet
    Jan 01, 2013 | Delta Victorian Widespread Bathroom Sink...
    The faucet base doesn't sit flush with the sink when installed. There is about a 1/4 inch gap between the sink surface and the base of the faucet.
    Typically there is a plastic piece that sits in the bottom of the faucet base. It has a up and down side. The "up" side has lines to reinforce the base as well as it is designed to fit snuggly in the bottom of the faucet. If it is upside down then those lines will hold it off the base.
    This should solve the problem. If not check the spacing of the water lines that protrude thru the sink and make sure that they are not spread to far or too little and not allowing the faucet to seat properely.
    Jun 30, 2011 | American Standard Town Square Countertop...
    Parts diagram for sigma faucet
    http://www.sigmafaucet.com/media/cms/specifications/400408.pdf
    I found this series on line at the link above the only number off one number off. Check out the link below for all sigma faucets. I hope this will be helpful for you.
    http://www.sigmafaucet.com/ecommerce/prod_details.asp?pid=1408470&img=&cid=816144586725
    Jun 14, 2010 | Home
    The moen adler tub/shower faucet came with a piping fixture that the hot and cold water come through and redirects water to the shower head. anyways, I have already replaced the tile in front of this. It...
    They make face plates to cover up removal of faucets in tile. They are chrome and will fit any 6" single handle faucet cover plate.
    They are used to cover up tile for removal of 8" spread faucets so you have a little room to move if you have to cut valve out and replace.
    Lowes started carrying them and a plumbing supply house should have them if not email me and I will try to get you a address to get one if this will help you out.
    They are about $15- $20 for it. Lowes carry them in NC .
    Jun 11, 2010 | Home
    New Price Pfister Ashfield Bath Faucet - Hot H20 pressure is weak
    I had the same problem. I simply removed the small brass fitting that the water supply screws onto.i removed the screen that is inside the brass fitting. Now the pressure is fine.
    Feb 15, 2010 | Price Pfister Pfister Ashfield Wide Satin...
    I just installed an american standard faucet Molel# 2808.222 Called SPREAD LAVATORY FAUCETS . The water does not come out. can you please help me?
    Silly question, but did you turn the shut offs back on after installing? If so, the aerator is probably clogged (the screen on the faucet). Unscrew it and clean it out. Good luck
    Dec 31, 2009 | American Standard Kitchen Faucet 6310 020...
    Home Logo
    Top Home Experts
    Donni Steen
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
