Question about Technics Audio Players & Recorders
I HAVE A TECHNICS RECEIVER SA-GX470. WHEN I TURN IT ON IT PLAYS OK. AFTER 15,30 OR 60 MINUTES OVERLOAD APPEARS ON THE DISPLAY. THE SPEAKER WIRES AR NOT SHORTED. PLEASE ADVICE
  • 2,632 Answers
Welcome to Fixya. If you have an Overload Error you need to check the cause of the problem.
1. It can be Too much power. i.e., turning up the volume too far?
2. Speaker impedance too low? (Check the specs on the speakers.) Or maybe a short on one of the speaker wires?
3. Faulty overload protection circuit.
4. Faulty output transistors in one or more channels
Run at a lower level to see if it is just too much drive power into the speakers (loudness). If still have a problem better check the system with a shop or a local tech to look at it.
If you have questions please let me know. Thanks for usin Fixya.
Posted on Mar 15, 2011
Overload sa-tx50
Most overloads are caused by the main output devices. They will go short circuit if for example speaker wires have come into touch. Another cause is high volume or a faulty speaker. Or poor ventilation around the amp causing excess heat.
The only cure is to replace the device(s) generally located on the heat sink.
Dec 01, 2013 | Technics SA-TX50 Receiver
My technics receiver stop playing, and display an overload message. what do you believe the is the problem ?
If you are getting an overload problem, it indicates an output load issue. Turn receiver off! remove speaker wires from the back of the unit, this will reset the protection circuit. Now power up and turn your volume right down, If the word overload stays off it means there is a short in the wire or speaker. But! if the word overload comes on "even with the wires and speakers dis-connected" it indicates a short in one or more of the audio output ic's or transistors.
Mar 17, 2011 | Technics Audio Players & Recorders
My technics sa-dx930 receiver stops working and an error message is displayed that says "overload" when i use the "b" speakers for my patio. This is a new problem. i have had the same outside speakers,...
Hey, I own one of these systems. Whenever I touch two of the wires together (shorting it out) the system shuts down and overload appears on the display. My suggestion is too check your wiring (especially in the spliced areas) or replace the wiring to the outside speakers and try it again. If you dont want to try that, take the wires you have hooked to the A speakers and see if they will work on the B setting (a quick troubleshooting technique). Please let me know if it worked for you. Good Luck!
Sep 09, 2009 | Technics SA-DX930 Receiver
We have had a Technics stereo for 16 years and have had NO problems until the last couple weeks. If the volume gets turned up, the signal will come on that tells us that there is an OVERLOAD. We have tried...
Disconnect the speaker wires at the receiver, turn up the volume, if it goes into protection, it's an internal problem and needs service. If it does not go into protection, re connect one speaker at a time and test. If it shuts down check the speaker itself, if they are as old as the receiver, chances are good that the surrounds on the speakers themselves have disintegrated. Older speakers used foam surrounds, newer ones use rubber or plastic composite material that will not disintegrate. What will happen is dust and moisture will get into the voice coil and cause a short, even though the speaker still plays. Hope this helps. If you need more help or just advice, post a comment, and I'll help if I can
Jun 28, 2009 | Technics SA-EX320 Receiver
Technics 940dx "overload"
Disconnect all speaker wires from the back of the receiver and turn it back on. If overload does not turn on, post a comment and I can walk you thru troubleshooting. If it does, your receiver needs to be serviced. Hope this helps
Jun 25, 2009 | Technics SA-DX940
I have a technics amplifier SU G75
I have a technics too, and faced the same problem. The solution is very simple just ensure the +ve and -ve wires are connected correctly for each speaker to the amp. Eg. red wire to the red knob and black wire to the black on both ends. sometimes this arises because the wires are of just one color however there will be some marking on the wire to indicate which is +ve and -ve. This took care of the overload problem.
Jun 18, 2009 | Technics SA-AX530 Receiver
Overload signal
The overload is the same as protect mode. Remove the speaker wires and turn the unit back on. If the message remains, there is a problem internal to the unit in the final stage of the amp.
Please let me know the results of the test above.
Thanks,
Dan
Mar 02, 2009 | Technics Audio Players & Recorders
I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Nov 16, 2008 | Technics SA-EX110 Receiver
Technics SA-GX470
over load means your speakers and its cable----please check it for bad cable or bad speaker------try to insert speaker one by one and test each time to investigate the bad one.--------if every thing is ok and you keep good ventilation around your receiver (no blocking of ventilation holes)and you still have a problem your protection circuit in your receiver needs to be checked by service technician
Aug 06, 2008 | Audio Players & Recorders
179 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
