Question about Refrigerators
Freezer side builds up water then freezes at the bottom.i think maybe there is a drain clogged but i dont know where o find the drain.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Ice build up bottom of freezer compartment and water leaking from un der the refrigerator i think maybe a drain is plugged and how do i fix it. and the model #mzd2766gew
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing.By pulling the ref. from the wall there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps,
Gene
Aug 05, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Clogged drain in freezer compartment
Hi and welcome to FixYa. I am Kelly.
The drain sometimes all on its own will freeze. Who knows why. The best was to ensure the drain is clear is to manually defrost the refrigerator. You do this by first unplugging the unit. Then empty the contents of the freezer. Use a fan and place it blowing into the freezer for a little over 2 hours. This will make a water mess so have the rags and mop ready.
After the 2 hour manual defrosting session take a toothpick and make sure the drain is clear. Use your baster and hot water to check it for sure. If it is still clogged remove the back panel of the refrigerator and check the end of the drain for debris. Often what happens is there is some unpleasant goo that builds up on the very end of the drain tube and then it dries n place once the catch basin is dry.
Other times the drain freezing over is a sign of an automatic defrosting problem. When it does not defrost the ice builds up on the evaporator coils and eventually it freezes over the drain. Usually when there is and automatic defrost problem the fresh food section warms up, the ice maker stops making ice and things like ice cream get soft.
Give the manual defrost and drain check a try first. If there really is an automatic defrosting problem in 3 to 4 days the symptoms will repeat.
If at that time you need more assistance just respond here and an expert will help you.
Thanks for using FixYa.
Kelly
May 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Water is building up in the bottom of my side by side freezer and freezing.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
May 07, 2008 | Freezers
Excessive Frost and Ice Build up in Freezer
Mar 20, 2008 | Refrigerators
Water freezing on the tray section under the freezer drawer.
Mar 15, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
