Question about Microwave Ovens
GE microwave Monogram Spacemaker II ZEM200SF03: The oven is 2 1/2 years old and for some time has been making a rumbling noise which is becoming more and more annoying. Otherwise it works fine. Any suggestions? Thanks
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 95 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Disassembly of GE JVM1460 microwave oven door to clean
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 10, 2008
Illeagle
  • 525 Answers
SOURCE: GE Profile Spacemaker II - Burning smell and no heating
You may have a failure of the H.V. rectifier. I would recommend that a trained technician replace this part due to the high voltage potential.
Posted on Jun 03, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Dualwave II MIcrowave System - use of the convention oven time
You can download GE owner's manuals and installation instructions here.
Posted on Jan 01, 2009
Ge spacemaker II microwave started humming and nothing showing on monitor
My parents have had a couple of the spacemaker microwaves mounted over the range with the built-in vent. Over time, the seal on the control board gets a crack in it and the steam from cooking below it gets up into the control board and does it in.
Even if yours isn't mounted over the range, it sounds like a main control board failure.
Sep 10, 2016 | GE PEM31DMBB Black Profile Spacemaker II...
Microwave making noise and no heat.
Sounds like the magnetron tube went out. Not cost effective to repair unless under warranty.
Feb 04, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven just quit. Have checked fuse and plug. Have had no earlier problems. Do these ovens just ''wear out''? It is 8 years old. It is a GE Spacemaker. (November 2002) GE Spacemaker Serial...
yes they wear out. usally the first part to quit is the unit inside that creates the microwaves called the "magnetron" over time they will wear out, and so will the circuitry that runs the entire microwave, some will last 8 years like yours, some only a year or 2. 8 years is pretty good for the life of a microwave. but yea, its time to get yourself a new one. good luck to you
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It is making a lound noise and no longer heats
heatman101
dgh
Oct 24, 2009 | GE Profile Spacemaker II PEM31 Microwave...
Microwave no longer heats; makes no sound or buzzing noise
hi..it sounds like a magnetron problem.It might have
got into damage.
check this out..
thank u..
kindly rate my response..
Jun 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Jun 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker XL1800
pull the cover off of the microwave and check for anything loose. ie fan bracket covers. check the 4 nuts that hold the magnatron in also. if that doesn't fix it maybe you can go to an appliance repair place and see if that have a magnatron tester which is just a piece of plastic with 4 bulbs in it and if the magnatron is working properly with that tester in the it will look like a red strobelight going off in the microwave. if not then your rumbling noise is the magnatron getting ready to go out good luck
Dec 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
70 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
