Question about Sewing Machines
The material sticks in the hole in the bobbin part of the machine
    Genius:
  • 1,788 Answers
Try using a tear away stabilizer, or gift tissue paper, even computer paper will work to get you started if your material is too thin. Also, use the right size needle and hold your threads when you are starting to sew a seam
Posted on Mar 17, 2011
What #holes on 158.1786181 solid state Kenmore sew machine bobbin
Do you mean the lower bobbin spool? It should not matter too much so long as it fits. Try it on a scrap of material and see how it goes.
Mar 02, 2015 | Kenmore Sewing Machines
How would to insert the bobbin in the sewing machine brother VX 1400?
There is not much of a secret to inserting a bobbin in a sewing machine. A couple of things to check, the thread from the bobbin should be pulled through the slot of the carrier, and make sure the thread comes through the sewing hole by manually lowering the threaded needle and then lifting it out of the hole again after it has picked up the thread from the bobbin. The video link posted below is useful if you have a Brother sewing machine.
If the stitching is still not right then check that the needle is fully inserted in its housing. (Push the needle up as far as it will go then tighten the screw.)
How to wind and install the bobbin and thread the sewing machine PART 2...
Aug 24, 2014 | Sewing Machines
My sisters singers brand new Athena sewing machine she just started jusing about 5 or 6 times just stopped picking up the bobbin thread and sewing thread in the material. It is just leaving holes in
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Jan 14, 2014 | Brother CS-8150 Computerized Sewing...
Machine just quit picking up bobbin thread and sewing in the material. It is just making holes in the material.
Needles need to be replaced every 2-8 hours of sewing time, on average, or about 1 needle per garment. A needle that has hit the presser foot or needle plate is "dead", and needs to be replaced to (and eventually, you'll need to buff out the rough spots on the presser foot, and needle plate).
Common causes of skipped stitches (stitching that looks like
_ _______ _ _ _______ _ _____________ instead of _ _ _ _ _ _) or of not picking up the bobbin thread are: dull or damaged needle, needle in backwards, needle not fully up in the needle clamp, needle too small a size for the thickness of fabric, dirty machine, misthreaded machine, and way, way, way down on the list, machine out of time.
Jan 14, 2014 | Singer Sewing Machines
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
Model No. 15358. I am having problems with my
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Sep 04, 2009 | Kenmore 15358
Bobbin area will not work
There should be a spinning cover with a hook that fits over the bobbin. Normally, you just pull the bobbin thread out through the swinging/sliding plate hole. Turn the machine by hand toward you (at the top) until the needle dives into and comes back with both threads. Separate the threads and assuming that the thread tension above the needle is set correctly, feed a piece of material in to see if it sews correctly. The tension is set so that the thread is even on both sides of the material. Let the machine pull the material through at it's own pace, your function is to guide the material.
Jul 17, 2009 | White Sewing White 3032
Machine is threaded but thread not sewing into material, just holes!
Check bobbin thread....Insert the bobbin thread into the bobbin case in a clockwise direction...pull the thread through the **** on side of bobbin case and slide up into small opening...make sure you pull through about 2 inches of thread to enable upper thread to loop. Good Luck
May 10, 2009 | Sewing Machines
Hi I am pretty sure that the bobbin and the thread are in correctly but when I put the material in the needle just put holes in the material. what am I doing wrong?
you may have adjusted the upper tension and made it so tight that the thread just pulls out of the needle and needle makes holes in fabric. you might want to check the feed of the bobbin, it will not allow the machine to sew if it is not able to be picked up by the needle. the bobbin thread is usually (when held in your hand) with the thread coming counter clock wise. and then it will lay in the bobbin holder and the end of the thread will come back to about the slide catch thing and be held there until the needle thread catches it (leave the cover off the bobbin area until you watch and see what happens then. Try adjusting the bobbing tension too hope you understand what I mean here.
Mar 07, 2009 | Singer 7444 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
