Is it the oil sending unit or is it possibly a leaking valve cover gasket.you have to narrow down the area the leak is actually coming from.if it is either of these then replacement is the only solution.
I think you need a new oil light switch ,they can and do leak through the internal seal of the switch which makes a nice mess on your drive
Clean engine and check exactly. Is from block or from some pipe or pipe end?
