I bought it at a street vendor. It copies the data but is very slow. And the data is most of the time corrupt. I swapped it at the vendor for another one but it does the same. Any ideas?
  • 27,725 Answers
You could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
also
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 15, 2011
I WOULD LIKE TO RETURN AN OVEN TOASTER WHICH i ONLY USED ONE TIME. I AM 90 AND FIND TOO MANY DIRECTIONS FOR MY SLOW MIND.
You are at the mercy of the vendor and how long it has been since you purchased it. Do you have the original packing materials and, instructions, etc?
Maybe the vendor will swap it for an easy to use unit in lieu of refund. Check it out.
Feb 03, 2016 | Black and Decker USA Black & Decker...
My Copy of Descent for ps1 says that my save data is corrupt, how to fix this?
check your memory card through the dashboard if it has corrupted data there's a good chance its your save can happen for a few reasons but mostly turning it off while saving
Nov 25, 2013 | Video Game Consoles & Games
My transcend JF v30 32gb usb format earre and don,t sho memory
Firstly,recover data from hard drive with datarecovery software.Then you can format it to check out whether it can befixed.For data recovery software,I have a professional one on my computer thatcan recover data after deeply scanning your hard drive to look for lost datadue to drive crash,system sabotage, virus corrupted partitions,etc.You candownload it and scan your hard drive for free to preview whether your data canbe recovered. Get it from http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Sep 13, 2011 | Transcend USA 120GB Storejet 2.5" SATA -...
It has been only 3 months since i bought my transcend portable 500 GB.up until now everything was fine.but now i'm facing some problems with coping files.when i copy files from external to internal...
Try to defrag you external hard drive, cek your hard drive wether there a bad ?
sometimes bad cluster can running slow for copying your data or else.sorry my english is poor.thank anyway
Jun 25, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Update 3.30 error 8002F994 data is corrupt
Actually, Reseting the console is your best bet. All you have to do is put your finger on he power button, HOLD IT DOWN for 10 seconds, and it should restart. If it doesnt reset the first time then do it a couple times.
Be Safe, kiddies. >:)
Apr 24, 2010 | Sony Playstation 3 (PS3) Console
Copy speed slow ( on bizhub c450 ) and show three angle shape
good luck
Description:
The machine copies very slow and well below the rated output for black and white and color.
Solution:
CAUSE: The machine memory is corrupt.
SOLUTION: Perform a data clear:
1. Browse to the NIC/Log on as Administrator/Select the Scan tab/Import Export and back up the one-touch addresses to the desktop.
2. Enter Tech Rep mode.
3. Select System 1.
4. Select Data Clear and press start. Wait for the machine to cycle OFF/ON and for the POWER OFF MACHINE WITH THE MAIN POWER SWITCH message.
5. Import the one-touch list back to the NIC.
6. Re-install the HDD and power the machine OFF/ON.
7. Reset the Marketing area to U.S. and the target to U.S.
8. Re-install the TCP/IP address and power the machine OFF/ON.
Sep 14, 2009 | Office Equipment & Supplies
Problems with pendrive data gets corrupted
Why not backup your remaining data from the pendrive. Then reformat your pendrive using full format. If it still behave like that , your pendrive is already giving up.
Apr 09, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
My ps2 memory card continues to corrupt data.
Try using a different memory card. The problem you have could be the card, but it could also be the playstation. The cheapest way to find out is to use a new or borrowed memory card that you know is good.
Play a game for a good while and try to simulate your problem.
If a different card does not have this problem, you know that the playstation console is fine.
If the problem happens again you will need the playsation repaired. That is the bad news. There are no repair centers except for the Sony factory repair center in Mexico that can get parts for these playstations.
That is the way Sony has set this up for the Playstation, I guess it saves them money.
I hope you found this information helpful, and if so, a good rating would be appreciated and even appropriate, even though the news is not really very good.
You can even call Sony to verify what I have said.
Thanks, and good luck, I hope you only need a new memory card.
Let me know if you need any more help.
Dave
Jun 21, 2008 | Sony PlayStation 2 Slimline Console
Computers & Internet Logo
David Payne
David Payne
