Question about Emerson SmartSet CKS1850 Clock Radio
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio on CKS1850
  • Emerson Master
  • 5,471 Answers
Unfortunately, you can't reset the firmware of the clock for those built before Jan 2006; you can work-around the issue. You will need to change time zones for the few weeks between the current daylight savings start and end dates and the ones that were built into the clock. For details see: http://www.emersonradio.com/dst.htm ; click on the link for Group 1.
If the unit was built before Jan 2006 (the serial number will start with a value less than 6), switch the time zone to the next one further east on the second Sunday of March, then set it back to your correct time zone on the first Sunday of April. Repeat this on the last Sunday of October and the first Sunday of November. (If you are in the Eastern time zone (zone 2), set the switch to zone 1.)
If the unit was built between Jan 2006 and July 2006 (serial numbers that start 601 to 606), then you can change the start and end dates for DST. See: http://www.emersonradio.com/dst.htm then choose the Group 2 link. Press and hold the Alarm 1 button then press the Month/Date or Calendar button. After three seconds the unit will display the start date for daylight savings. Press and hold the Alarm 1 and Month/Date or Calendar buttons. When the display is flashng (within 5 seconds from the press and hold step), press the Down or Set button (depending on the SmartSet mode) three times until the display reads 3 and F2 (alternating with the date of that Sunday).
For the end date, press and hold Alarm 2 then press the Month/Date or Calendar button. Then press and hold Alarm 1 and the Month/Date or Calendar button. Again within 5 seconds, press the Up button or Set until the display shows 11 and F.
If the display stops flashing, repeat and set the new dates faster.
You'll have to repeat this is the battery is removed or replaced.
I hope this helps.
Posted on Mar 15, 2011
I am having problems setting the alarms on my Emerson Smart Set clock
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
And this conclude's Search Marketing Guru's public service announcement. :) We'll be back with relevant online marketing posts with our next posting!
Nov 03, 2010 | Vacuums
How to reset Emerson SmartSet AC100 Alarm/Radio for DST changes!!
No way to change it to automatically do it without replacing the data chip. I changed the time zone from 3 to 2 in the fall and then have to switch back to zone 3 in April.
Apr 03, 2009 | Emerson Smartset Clock Radio
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Daylight Savings Times Changed
We set the time zone to '7' , which is Hawaii time zone where there is no change for daylight savings. This came up because it changed automatically on this morning...and although we can change it back, then it won't change next week when it should. So we're hoping that by setting it to Hawaii it will be a regular clock, we will do the changing...but at least we won't be surprized as we were this AM.
lb
Mar 09, 2008 | Emerson SmartSet CKS1850 Clock Radio
There was a sheet of paper that came with my clock explaining how to adjust the daylight savings time settings, but I lost it.  Anyone have theirs?  All i know is it requires that you press an awkward combination of buttons simultaneously, but that's it.
Nov 06, 2007 | Zenith Z230S Clock Radio
Help daylight savings time is not here yet
I am going to try changing to time zone 7 (Hawaiian Time). Hawaii does not observe DST so this should turn the clock into a regular clock that ignores DST and you need to set yourself twice a year.
Oct 30, 2007 | Emerson SmartSet CKS1850 Clock Radio
Emerson Smartset Radio Model CKS2288
The Daylight Saving dates appear to be hard-coded per the manual:
Start of Daylight Saving Time:
At 1:59.59 AM on the first Sunday in April, the clock will automatically advance to 3:00 AM.
End of Daylight Saving Time:
At 2:59.59 AM on the last Sunday in October, the clock will automatically reset to 2:00 AM.
So the easiest thing to do is to change your time zone up or down one for the period between the new DST date and the old -- or you can buy a new SmartSet for about $15. The newer ones do not have the same problem.
Oct 29, 2007 | Emerson Smartset Clock Radio
Hello everyone,
I finally found a manual that I hope that it will help you as much as it helped me. It took long enough. Here goes; try this site:
http://www.emersonradio.com/owners/SmartSet%20Series/
Oct 28, 2007 | Emerson Smartset Clock Radio
558 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
