Question about Ovation MM68-CCB Acoustic Electric Mandolin
I have a 88 gmc sierra 1500 pickup with a 350 and throttle body it runs like it is stuck on choke i have replaced o2 sensor,throttle position sensor,fuel temp.sensor and removed thottle body and cleaned but still does the same.
    Champion:
  • 299 Answers
Check injectors
Posted on Mar 15, 2011
  • Steve Jordan
    Steve Jordan Mar 15, 2011
    i can unplug either injector and it runs ok on 1 but plug both in and act like it getting to much gas.
I have been looking for a wiring diagram for months to install these v7 and v8 pickups out of an Ibanez mtm2 into my Ibanez 350 dx. please help!!
The most comprehensive diagrams for different pickup configurations is on the seymour Duncan website. You should find the info you need there.
Dec 10, 2015 | Ibanez Music
Fender troubleshooting
Replace the selector switch. $15 DIY or $40-$50 Pro installed.
Jul 27, 2014 | Fender Modern Player Telecaster Thinline...
Bridge pickup works with toggle switch up but in middle does not and in down position lower pickup doesnt work
try checking out the wiring on your switch...if all is good try replacing the switch altogether...one of the other is bad...Good luck
Feb 15, 2014 | ESP Music
I have an Epiphone Les Paul Custom Silverburst, and it's pretty new and has worked great until now. It seems my bridge pickup lost tone and volume for some reason. My volume and tone knobs are cranked...
Need more info: 1- does the volume control still change the level? 2-Does tone control still change the tone? 3- What happens when in the center position on pickup select switch? Put pickup switch in center position (both pickups active). Then take a coin and tap on the pickups. Does bridge pickup sound lower? Lastly remove rear electronics cover and inspect all wiring for something loose or disconnected.
Aug 26, 2011 | Epiphone Les Paul Special II Guitar...
Single coil feeds back in the the 3 position
Replace with a potted/waxed pickup. Play with less gain or not so loud orstand further from or beside the amp.
Jun 30, 2011 | Fender American Deluxe Telecaster
I need to know how the five way switch works. I don't know which switch position turns on which pick ups.
In a guitar with 3 pickups a 5 way switch works like this. With the switch all the way forward( towards the tuning pegs) the pickup closest to the tuning pegs or end of the neck is completely on ( if your volume control is all the way on). The next position (moving away from the tuning pegs or neck) is a combination of the neck pickup and the middle pickup. The third position moving away from the neck is completely the middle pickup. The fourth position is a combination of the middle pickup and the bridge ( where the strings are fastened) and the fifth position is completely the bridge.
Nov 15, 2010 | Washburn Electric Guitars Modelno X11B
I have a guitar im trying to install new pickups on but they set down inside and mount directly to the wood underneith and i cant keep the springs from falling off this does not use a mounting ring or a...
Try holding the pickup in the cavity in the position you want without the springs. Use a bit smaller than the mounting holes in the pickup to predrill the holes in the body through the pickup holes while you are holding the pickup in place. When you are ready to mount the pickup use a little hot glue on the ends of the springs to hold then in place over the mounting screws on the bottom side of the pickup. With the screws and springs in place on the pickup carefully screw the mounting screws into the predrilled holes in the cavity. Try using a pin vice to hold the drill bit or one of those small drills that you can operate with one hand( your second finger and thumb hold the slider and your index finger does the downward stroke). Here is a link to a really good site:http://www.stewmac.com/freeinfo.html
Jun 01, 2010 | DiMarzio Dp215 Evo 2 Bridge Pickup Regular
I'm think about buying an alexi 200 guitar, but i want to replace the esp pick up for an emg 81. Is there a place for the battery the pickup will require?
There should be enough room inside for the battery. If there isn't you could do some routing to the body to make it fit. I personally don't have this guitar but more than likely you can position the 9v battery to fit. To keep it from moving around, you can put a piece of sponge in the cavity.
Jun 09, 2009 | ESP Ltd Alexi 200 Electric Guitar
Ovation MM68-CCB Acoustic Electric Mandolin Logo
143 people viewed this question
Top Ovation Music Experts
Computer Links
ray gallant
rhodesworks
Are you an Ovation Music Expert? Answer questions, earn points and help others
