Question about Toshiba Televison & Video
Toshiba television Model #50H81 comes on with a clear picture but after 15-30 minutes picture is full of static. Any help will be appreciated! Patty
  • 10,594 Answers
It seems tv got problem of bad capacitors in hyper module, please replace all bad capacitors in hyper module to solve problem.
Hyper module is long circuit board covered with metal shield located on signal board of tv. Capacitor replacement requires good soldering skills and if you do not have such experience, please call local tv repairman for that job to avoid any damage of circuit board.
Hope these info will help you.
Thanks.
Posted on Mar 15, 2011
When I turn on my rear projection tv,the color will float & the picture will shake side ways. My tv is a toshiba 50h81 model ,also it is a HDTV as well .
it's capacitors on the three line board. difficult to replace. I would recommend taking it to A professional. It will get worse over time.
Dec 09, 2012 | Toshiba Televison & Video
Have a MODEL 50h81 and after about 10 minutes the screen goes snowy - not the cable wire checked and tested - can this be fixed?
I Just had My Sony 46" Fixed It really Was A Circuit Board But The Wife Charged me For MotherBoard And Tuner But I Talked To Tech It Was Just A Circuit Board I got ripped Off Be carfeull Who You Call.
Sep 02, 2010 | Toshiba 50H81 50" Rear Projection...
When we turn on our Toshiba 50h81, it will work ok for 45-90 minutes, then without warning, the picture and sound will go off and the power light blinks. We have to let it set for awhile (I've never timed...
These Toshiba TVs have a problem on the power board that causes this issue and it is a common one. There are several capacitors on the power board that seem prone to coming loose over time. When they lose connection for a moment the TV's protection system steps in and cuts off power. This causes the 'blinking power light' issue. The last one I repaired was a 43V71 model and I re-soldered one loose capacitor on the power board and it has worked perfectly ever since. Toshiba put out a service bulletin on this problem. It is well known and well worth fixing.
Nov 11, 2009 | Toshiba 50H81 50" Rear Projection...
Hi i need a picture tube (the blue crt) what all models and sizes of Toshiba fit if i was to go used? It is a toshiba 50h81
You can also use picture tube part number 23008517 which is in model 57H81. Please note that these tubes are no longer available frmo Toshiba.
Dan
Nov 02, 2009 | Toshiba 50H81 50" Rear Projection...
Scrambled picture
I have the same problem here as well, except that it has been happening so long that now it doesn't get completely clear. The picture was great at one time :-(
Jul 07, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50h81 has power but no picture or audio
is your high voltage still comming up?
ok turning up screen controls with tv on. what do you see?
Apr 11, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 Has Power but No picture or Audio
ok i'm goin to need more info about your problem. you stated fuses and didn't say the location numbers of the fuses. Also, have you rechecked your fuses to see if they are all still good? 3 fuses sounds like more then one problem. once you tell us your loc#'s of your fuses, we can look into your problems.
Apr 07, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81
convergence amp ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 16, 2008 | Toshiba 50H81 50" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
